Automatic Tranny Woes
Old Mar 11, 2011 | 08:46 PM
TheTowingCowboy's Avatar
TheTowingCowboy
I was talking to a buddy of mine (Who put a 7.3 in a 67 F250) and he was telling me that the VSS send a signal to the speedometer, then the speedometer changes the signal type and sends it to the tranny to tell it when to shift. Is this true or not? Cause I want to have to use the dash from the 95 nor do I want to use the cluster, I plan on making the highboy a minature semi. So all help I can get would be appreciated.
Old Mar 11, 2011 | 09:47 PM
oldbird1965's Avatar
oldbird1965
I think the VSS sends the signal to the PCM and PCM sends it to the speedo. The rest I don't know. In fact, I don't know for sure if my first sentence is correct? LOL
Old Mar 11, 2011 | 11:31 PM
chicagodragon's Avatar
chicagodragon
iam pretty sure the pcm/vss tells the tranny when to shift. not the speedo.
Old Mar 12, 2011 | 01:06 AM
BuckHammer's Avatar
BuckHammer
I think Glenn is right here.
Old Mar 12, 2011 | 09:34 AM
TheTowingCowboy
Okay so I shouldnt need the speedometer from the 95, jsut get one that will read the signal from the PCM? Hope you all are right!!
Old Mar 12, 2011 | 05:50 PM
glasseater's Avatar
glasseater
i can't see a reason why the 95 dash WON'T work
edit: whoops i think i misread your post... but i would think that anything from the 94.5-97 year range would work fine
Old Mar 12, 2011 | 06:01 PM
TheTowingCowboy
I want to keep the dash a 75 dash, I dont want to use the stock cluster I want to (If I can) get all Kensworth gauges to do a new cluster for the 75.
carhartted
Jun 20, 2008 07:02 PM
paulcalif
Nov 7, 2005 10:27 AM
dirtyshorboy
1978 - 1996 Big Bronco
Jul 17, 2003 11:38 PM
rcbisset
Sep 11, 2002 12:29 PM
