windshield rubber
Old Mar 11, 2011 | 06:53 PM
sly_buck's Avatar
sly_buck
windshield rubber
windshield leaks in upper corner just foud this looking inside the truck while raining, heres the problem - pulled the seat to get redone, carpet trashed its a perfect time to replace it, now dont want to put the carpet or just recovered seat in until it stops raining in truck, NOW has anyone had to replace the rubber seal and did you have any luck or problems, since it looks i will be doing window work i will have the back glass and rubber replaced also, it just one thing after another. again i just pulled this truck out of a farm pole barn 4 weeks ago and sure to find more
Old Mar 11, 2011 | 07:45 PM
Action4478's Avatar
Action4478
Most likely , it is not the gasket ,,, you most likely have rust ...
The glass is easy to remove ...
Old Mar 12, 2011 | 02:34 PM
sly_buck's Avatar
sly_buck
i dont think rust you can see the rubber cracked in several places, i am looking for the right place to get the rubber correct the first time
Old Mar 13, 2011 | 09:59 AM
sly_buck's Avatar
sly_buck
ready to order gasket and now more questions, i see a wide and narrow trim gasket includes windshield - back glass - both doors and not sure which i have, the chrome molding is 1" wide does not have corner pieces, can someone help identify???
Dennis Carpenter has these kits
CAB73-B
- groove for wide metal type chrome
D3TZ-1003110-E - w/chrome groove
D3TZ-1042084-C - w/chrome groove
D3TZ-1020530-PR
F100/350 73-79 200.00
kit
CAB77-B
- groove for narrow plastic type chrome
D7TZ-1003110-B - w/chrome groove
D7TZ-1042084-A - w/chrome groove
D3TZ-1020530-PR
kit
Old Mar 13, 2011 | 10:09 AM
ranger429's Avatar
ranger429
You have the stainless trim I take it. You need this one: CAB73-B
CAB77-B is for the plastic chrome trim.
Old Mar 14, 2011 | 01:22 PM
79FordBlake's Avatar
79FordBlake
I have the trim around my windshield and I got the seal from Dennis-Carpenter. I had a new windshield and seal installed at the same time. Old seal leaked in the corners. Took it to be professionally installed and they found no rust, new seal still leaks in the corners so I got to take it back and they are going to inject sealer.
Had the seal in the back glass replaced also and so far it hasn't leaked.
Old Mar 14, 2011 | 07:38 PM
sly_buck's Avatar
sly_buck
79fordblake which seal did you order, i was thinking of getting the kit with the doors also
Old Mar 14, 2011 | 08:12 PM
4x4 Bart's Avatar
4x4 Bart
All seem to leak at the corners and as much as a foot inward even with new rubber and no rust. Gently peal back the outside rubber at the corners and inject clear silicone sealer, then wipe off any excess. May take a couple of times to get it good enough to prevent rain from coming in across the top edge.
GeneGregory
Nov 3, 2015 02:43 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
17
Jan 29, 2015 01:55 AM
Evan_P
46
May 11, 2014 06:14 PM
Luch
Oct 17, 2013 03:43 PM
big red c222
2004 - 2008 F150
16
Nov 6, 2007 04:48 PM
