302 Fuel Consumption
Old Mar 12, 2011 | 12:39 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Originally Posted by Brian_W
Ok... Here's all the digits I got, should I be getting 3 digit codes and 2 digit codes? Here's what I found.
3 3 4 3 3 4 - 1 - 3 3 4 4 5 2 3 3 4 4 5 2
So I am guessing 334 / 334 / 1 / 33 / 44 / 52 / 33 / 44 / 52 ????
33 = (for trucks) EGR valve not closing properly/ might explain o2 always lean
Remove /clean EGR valve & EGR portway's on air intake manifold/ check integrity of EGR diaphragm & EGR for proper function.
52 = probably because you didn't move the steering wheel at the appropriate time during the scan.
44 = thermactor air system fault. check connections to thermactors
$22.77 = cut's a lotta crap!
Old Mar 12, 2011 | 12:48 PM
Brian_W's Avatar
Brian_W
Thank you so much, I will be ordering me one of those from the website you sent to me.
44 = thermactor air system fault. check connections to thermactors... I am not familiar with this? Where is it located?
Old Mar 12, 2011 | 01:07 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Those would be the "TAB" & "TAD" Solenoids.
Assuming I guessed correctly, deciphering your code string. I wouldn't spend any money on parts till you get your Code Reader & retest. Probably the best "Andrew Jackson" you ever spent on your truck! (If anybody else made sense of the number string, feel free to jump in!)
Old Mar 12, 2011 | 02:02 PM
Brian_W's Avatar
Brian_W
I appreciate all your help and assistance.
I checked the EGR Valve out, and it appears "NEW" on the inside. My Father-in-law (who gave me the truck) said the EGR Valve was replaced within the past year.
I have read a few other posts and seen people saying the EGR Position sensor is known to go bad? I have one on a another motor (not currently in a vehicle), should I try swapping that out, since it won't cost me anything for it?
I checked the connections on the TAB & TAD Solenoids, they were clean and tight.
Once again thanks for all your help, and if you think of anything else please let me know. Until then I will have to wait till I get the code reader.
Old Mar 12, 2011 | 02:23 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Here's something. When engine is idling at norm op temp, pull the Vac hose off the EGR.
There should be no vacuum from the hose. Possibly a palpitation of air, but no vacuum. If vacuum is present, suggests a problem w/ the EGR Regulator.
33 can be valve mechanical failure or obstruction of the valve seat or regulator providing Vac at the improper time.
Old Mar 12, 2011 | 03:21 PM
Brian_W's Avatar
Brian_W
There is a VERY FAINT vacuum from the hose. Not a palpitation, but a continuous VERY FAINT vacuum.
Old Mar 12, 2011 | 04:44 PM
ymeski56's Avatar
ymeski56
Der Postmeister
EGR Regulator. http://www.fordfuelinjection.com/?p=43
Djeap1977
Jan 24, 2017 12:46 PM
hyster
Dec 27, 2016 11:05 AM
Adam Spurgeon
Jul 31, 2015 08:33 AM
Rum-N-Gun
Sep 12, 2013 09:20 AM
lmd91343
15
Mar 27, 2011 02:51 PM
