I have a 91 F-150 with a stock 302, the only change was removal of a bad A/C compressor. I have a idler pulley installed in it's place. On to the question/issue I am having.
I drive mostly country roads 55 - 60 MPHs, and very little in town driving 25 - 35 mph. I did have a miss fire and located a burnt spark plug wire, where it had been too close to the exhaust manifold. After changing the wires (yes, I changed and re-routed all of the wires), the truck went up to 15 MPG for one tank of fuel, then next three tanks have been right at 10 MPG. I am puzzled as how I could get that much of a drop without any obvious signs of problems.
I have checked all the wires, vacuum lines, cap, rotor, changed the coil with another one (no difference), checked fuel lines for leakage. I am stumped! Please Help!
Do you have dual tanks? If so is the mileage the same between the two? Have you checked for codes? Many times there can be a problem without having a Check Engine Light on.
Yes I do have dual tanks, they both are getting the same MPGs. No I haven't checked for codes, as I do not have a code reader, I'll stop in by the auto parts store to have them read codes.
Any time spend below norm op temp will be low MPG. Short trip stop & go are MPG killers.
The shortest trips I take in the truck are at least 20 miles. Most are 30 - 50 or more. But I do agree with you on the short trips, still I would expect at least 12 - 13 on short trips.
Sorry about that, yes those are read in KOEO... And the Engine was in Normal Operating Temp Range. ( I drove it about 25 - 30 miles just before testing, to warm it up. )
Not sure if these will make sense to you, but that's how I counted it.
you may want to run the test again and recount. it should give a list of codes and then repeat the list, it looks like in the second group you have a number off on a couple codes.
Ok, I had the wife come out with me and had her count the blinks as well. Today we came up with completely different results. Here's what I got. These were read KOEO...
How old is your O2 sensor. More than 60K miles, replace.
66 = TOT sensor input below self test, or vane air flow circuit below minimum (E4OD)
Never seen that code before! TOT = Transmission oil temperature sensor.
I think I am going to reset codes, drive it a good 20 miles. Then I'll try reading codes once more. I was advised by my brother that he had disconnected battery last night after I read the codes!
As for the O2 sensor, no clue many miles since last O2 sensor. So I will look into replacing that.
Good idea & brother!
This should pretty much clear your continuous memory codes & leave you w/ your actual "active" codes. & KOEO's should be dealt w/ before moving to KOER's in order for them (koer) to be considered reliable.
