Ethanol Gasoline
Old Mar 11, 2011 | 10:39 AM
  #31
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by Wyowanderer
You'll be fine, don't worry. Your '85 is designed for use with AT LEAST 10% ethanol, and I've run 25% in my truck a couple time with no adverse effect. Carb/fuel pump and other fuel system gaskets have been made to tolerate "gasahol" since the late 70's.
The Factory parts have been made to last with Gasohol (ethanol), but what about the china made aftermarket stuff? Makes you wonder if that's taken into concideration with all the problems being reported...
Gasohol (Ethanol) has been around since the oil embargo of 1973, and the fuel crisis of 1979.
Our trucks can handle 10% from the factory, with new clean fuel systems.
It's the 15% that has me concerned.
  #32
Shark Racer's Avatar
Shark Racer
Originally Posted by 81-F-150-Explorer
Well, I believe ethanol emissions are as toxic as any other cellulosic material that is burned. Wood, grass, Rice, your wife's burned and smoking homeade bread.
Just because you may be able to drink, eat, and metabolize it in it's pure form, without ill effects, does not mean you can burn it and breathing the fumes won't kill you with enough exposure.
I guess you cook at your house too?
Old Mar 11, 2011 | 10:43 AM
  #33
Galendor's Avatar
Galendor
Good points, I agree. Sure, i wouln't want to burn ethanol and breath the fumes. Likewise with gasoline. I just mean I don't know of any reason why burning ethanol is worse than gasoline. It probably has to do with the purity of the fuel, in that any toxicants from either fuel are probably due to contaminants (e.g. the nitrogen they put in gasoline, or heavy metal contaminants). In pure form, burning ethanol or the hydrocarbons of gasoline doesn't produce anything other than CO2 and water. So released toxicants from either must come from contaminants in the fuel or engine.
Old Mar 11, 2011 | 10:47 AM
  #34
Galendor's Avatar
Galendor
I agree - potentially going to 15% is a concern. One poster here indicated his factory manual said "up to 15%" was ok. I hope that is true, and i'll check my '86 manual again to see what it precisely says.
Old Mar 12, 2011 | 03:44 PM
  #35
81-F-150-Explorer
Ethanol gasoline and the effects on O2 sensors
[ Moderator's Note - I had 81-F-150-Explorer add a comment he was composing when
this thread was originally closed yesterday, all else remains the same. -ct ]
It's not the oxygen sensors fault for lower fuel mileage with ethanol blended gas. The blended fuel has less BTU's per gallon, so naturally you will get less power and fuel mileage. Here's a link.
Fuel Economy Impact Analysis of RFG | Gasoline Fuels | US EPA
Actually, both points are concidered valid. You get a "Double wammy" so to speak. Not only are the BTU's lower, but the O2 sensor can get a false lean reading.
Again not as prevelant a problem with E-10 although it's still present. It's the higher 15% ratio that concerns me.
Sources:
http://www.nrel.gov/docs/fy03osti/32206.pdf
http://www.ehow.com/facts_7794427_effect-ethanol-blends-oxygen-sensors.html
Old Mar 12, 2011 | 09:09 PM
  #36
ctubutis's Avatar
ctubutis
Move on, move on, nothing to see here
Originally Posted by arcaidy
In the time it took you to make that post you could have looked it up yourself..
Originally Posted by old409
If you want a link or source, which one of several million do you
want? There has been considerable research done on the subject and some of us have read up on it instead of jumping on people and demanding THEY TELL US.
" I read it on the internet, so it must be true." That makes as much sense as "the government demands we do it, so it must be good for us." There are credible and authoritive sources everywhere for those not too lazy to seek them out.
Local tv here where I live did a special piece on it with several "certified mechanics" talking about the damage and problems they are seeing from ethanol usage.
Some people do take the time to check into things. I did this after my gas mileage and performance went to he77 in an ethanol handbasket.
Get off your lazy bottom side and check it out for yourself. The information is there. I don't give a Rat's Azz" if you believe me or not. I've been there and done it. Evidently, your ignorance is exceeded only by your laziness.
Sorry, but I don't agree. And, since it's my forum, my feelings are the ones that matter
most.
It is NEVER the reader's responsibility to look up and verify information presented as fact
to him, this is like handing in a research paper to your college prof and asking him to go
look up and verify the claims made in it.
At a minimum, you will get an F on the paper.
As I mentioned in the beginning, these types of threads tend to eventually degrade into
unsubstantiated (mis)information & hype followed by name-calling & insults, I hope the
OP has gotten enough useful information to help him with his questions.
As I also mentioned at the beginning, I and the rest of the metro Denver area have been
burning the stuff since the early 1980s and the sky didn't fall, nobody's engines suddenly
melted as a result so let's not be accusing me of being ignorant and needing to go do
some academic research, OK?
FTE is a G-rated, family-friendly forum, thanks go to all who posted useful and
non-sensationalized posts.
We are now done here, please move on.
yosemite98
37
Jul 15, 2017 04:53 PM
scottperkins
1997 - 2003 F150
Jun 29, 2016 10:33 PM
coley909
6.2L V8
Jun 5, 2016 11:00 PM
blueeyedfordguy
Alternative Fuels, Hybrids & Mileage
19
Apr 20, 2010 12:10 PM
mrad
Jan 26, 2010 08:28 PM
