Fuel filter restriction?
Old Mar 10, 2011 | 07:07 AM
ttttmaxx's Avatar
ttttmaxx
My 02 Dually had what I presume was the water in fuel light pop on last night. It looks like a fuel pump with a few drops over the top? Is this also a fuel filter restriction warning or is there another warning light for that? Thanks Maxx
Old Mar 10, 2011 | 07:23 AM
riverrat41's Avatar
riverrat41
That light is a water in fuel light.I would suggest drain the fuel from the bowl.Change the filter if it is dirty or has water dropplets on/in it.I think you will be good.
May want to add a little Diesel Kleen to the tank.
Old Mar 10, 2011 | 07:35 AM
ttttmaxx's Avatar
ttttmaxx
water in fuel
Is there a seperate light that comes on for clogged fuel filter? Or is this the only warning light tied into the fule filter? Thanks
Old Mar 10, 2011 | 07:40 AM
Robert6401's Avatar
Robert6401
There is nothing thats going to tell you if your filter is clogged. This would be a fuel pressure issue and nothing monitors fuel pressure on our truck. In order to know what the fuel pressure is you have to install a separate gauge.
Old Mar 10, 2011 | 07:42 AM
ttttmaxx's Avatar
ttttmaxx
Thanks Guys......
Old Mar 10, 2011 | 07:46 AM
riverrat41's Avatar
riverrat41
I am just betting if you will drain and clean that bowl.Install a new filter you will be good.If you have alot of water in the tank you may need to drop it and get the water/trash out.
Onus
Sep 9, 2012 02:34 PM
TexasDiesel97
Nov 26, 2011 05:57 PM
ConvertedFord
Mar 26, 2010 06:00 AM
esmarkey
Feb 2, 2009 09:20 AM
dieselphil
Mar 19, 2008 08:34 PM
