Adding cruise control
Old Mar 10, 2011 | 01:24 AM
autoxbird's Avatar
autoxbird
Hi all, I'm looking to add cruise to my '91 F250 custom 2x4, 460 with a E4OD. Any good kits out there, or how hard is it to add the OEM system?
Old Mar 10, 2011 | 10:02 AM
nstueve's Avatar
nstueve
not hard to add the oem system. You need the steering wheel cover with the buttons and then look under the hood of a truck with cruise... there will be 2 cables hooked to the throttle cable plate by the carb. one is the throttle cable and the other will be a vaccum controled cruise control system. Take everything behind the cruise control cable back to the wiring and vaccum lines... then reverse your tear out onto a install on your truck!
dylansf23
20
Apr 23, 2025 02:57 PM
762X39
1997 - 2003 F150
Feb 18, 2012 05:08 PM
benblaque
1997 - 2003 F150
Aug 15, 2009 01:13 PM
Flea
Nov 28, 2007 01:17 PM
jj292
Feb 1, 2004 09:50 PM
