Adding cruise control
Hi all, I'm looking to add cruise to my '91 F250 custom 2x4, 460 with a E4OD. Any good kits out there, or how hard is it to add the OEM system?
not hard to add the oem system. You need the steering wheel cover with the buttons and then look under the hood of a truck with cruise... there will be 2 cables hooked to the throttle cable plate by the carb. one is the throttle cable and the other will be a vaccum controled cruise control system. Take everything behind the cruise control cable back to the wiring and vaccum lines... then reverse your tear out onto a install on your truck!
