Cab/front clip is bolt hole exchange, bed area will have to be modded. As mentioned the back of the cab was lengthened in 73 behind the rear cab mounts so the chassis is longer to accept.
Correctly posted the chassis were different, but the front body mount locations are same. There is not a 2wd and a 4wd body.
if the bolt holes for the cabs are the same then that part should be relatively easy and if there is a gap between cab and bed you could put a roll bar in there off of the frame or a set of stacks !
