The spider
Old Mar 9, 2011 | 01:17 PM
Snowseeker's Avatar
Snowseeker
The spider
Ever since I first seen under the hood of the PSD back in 2000 I have always wondered about the design of the spider on the turbo cold side. The hot air is leaving the turbo threw half of the spider which would heat the spider. After running threw an intercooler the cooled air runs back threw this same heated spider then down into the heads. Isn't the one piece spider slightly defeating the intercoolers purpose? Wouldn't it be better if these pipe were separated from one another?
Old Mar 9, 2011 | 02:22 PM
duck fan's Avatar
duck fan
Because racetruck
There are products on the market that do this but none of them have shown noticeable gains. You are better off ceramic coating the stock spider
Old Mar 9, 2011 | 06:04 PM
SpringerPop's Avatar
SpringerPop
At the speed the air goes through the spider, it isn't going to pick up much heat.
Pop
Old Mar 10, 2011 | 07:29 AM
Snowseeker's Avatar
Snowseeker
Second question while we are on it, is the spider restrictive at all? I haven't had one out to look at it closely at all. it would be easy cheesy for me to build a new separated spider.
Old Mar 10, 2011 | 08:02 PM
bluescrew's Avatar
bluescrew
do it!!! and post lottttsa pics!
Old Mar 10, 2011 | 08:06 PM
Snowseeker's Avatar
Snowseeker
Wouldn't be till summer when I have extra time.
Old Mar 10, 2011 | 08:35 PM
countrycar's Avatar
countrycar
I took mine off to work on the turbo, and while I had it off I polished it out. I don't know how much of a difference it made as I didn't do any sort of Flow measurments. But what I did notice was a change in the pich of the sound come'n from my 38R. Kinda nice too..
Old Mar 10, 2011 | 09:39 PM
Bigcat350's Avatar
Bigcat350
I don't think the spider will restrict any motor we will build
Old Mar 10, 2011 | 10:05 PM
bdrummonds's Avatar
bdrummonds
If you are worried about heat transfer from the hot to cold side of the spider, it can actually be cut apart with a band saw, and a piece of rubber insulation inserted between the two pieces. there is enough metal between the two sides to not give up any rigidity. there is also a $400 aftermarket two piece PVC spider, that has no supporting documentation as to any temp or flow improvements over a stock spider.
Old Mar 10, 2011 | 10:09 PM
snakedoc's Avatar
snakedoc
x2 for no shown gains
Old Mar 10, 2011 | 10:52 PM
mueckster's Avatar
mueckster
My Aerforce Interceptor scanguage is only showing a 10-15* difference between ambient and air temp at the spider with my current mods, so I don't think heat transfer is an issue with its design. I did port the inside awhile back. Doubt it made that much of a difference.
Old Mar 11, 2011 | 07:35 AM
Night Crawler's Avatar
Night Crawler
when you say port, you mean polished? I would think if you polished the inside it would flow a little nicer, pennies on the dollar results though no matter how you look at it.
Old Mar 11, 2011 | 07:56 AM
Snowseeker's Avatar
Snowseeker
Yeah you just cleaned the casting up. Thanks for the info guys! I figured the air wouldn't get heated much with how little surface area there is. It also looks pretty free flowing like you guys mentioned. It is just a simple thing to build so I thought if there are any gains to be had it would be worth it.
Old Mar 11, 2011 | 08:03 AM
mueckster's Avatar
mueckster
The I.D. was enlarged slightly and the interior smoothed out. I used a carbide burr, followed by sanding rolls and a flapper wheel. Just a little time and a few bucks. Had most of the stuff already from my hotrodding days in the early 80's. Just tinkering.
BEFORE AFTER
Old Mar 11, 2011 | 08:54 AM
SkySkiJason's Avatar
SkySkiJason
I did what Roland did, but I wasn't as aggressive at removing material. I just tried to round off the edges a bit and SMOOOOOTH it out in there. I doubt it did anything, but I couldn't help myself.
1973dieselhighboy
Jan 26, 2015 12:31 PM
crash1
Mar 16, 2012 07:04 PM
rat49f6
17
Jul 13, 2009 05:12 PM
wmiller
23
Nov 5, 2008 08:38 PM
7.3 Powerstroker
Jan 15, 2008 05:40 PM
