04 Lariat Temp Gauge Reading Low
Hi all, I've got an issue with my 2004 F150 Lariat. I replaced the original engine with a new one from Powertrain. I've put a few hundred miles on it, and it runs great. The first cold morning that I drove it, I noticed the temperature gauge not registering where it normally does. After about 50 miles CEL came on, don't remember the code number, but it was coolant temperature too low. When I replaced the engine, I replaced all the parts of the cooling system. My first thought was maybe the thermostat was sticking open so I checked it first and it's working fine, coolant level was good also. Must be the CTS sensor under the intake of course since it was the one sensor that I didn't replace. That didn't fix it either. Then I unplugged the sensor and checked the voltage at the plug with the KOEO, I believe I read through searching it should register 5 volts, it read exactly 5 volts. I checked the ground at the plug and it checked good as well. I read that the PCM sends the signal to the temp gauge. I also tried the "gauge cluster check" but I haven't got it to work for me ? If anyone has any ideas, or can help me troubleshoot this issue, I would be grateful. Thank you.
v/r,
Parker
v/r,
Parker
v/r,
Parker
v/r,
Parker
Wanted to post an update. I plugged the harness back in at the firewall and fished it under the intake. I removed the alternator so that I could squeeze my hand into the tight spot and plug in the CHT sensor. Topped off the coolant and fired her up. With the scanner hooked up, I waited for the engine to warm up. The temp gauge came up to it's normal place, and the scanner showed the engine temperature @ 194 degrees. I honestly believe that I didn't give it enough time to warm up after swapping the CHT sensor. I'll keep an eye on it.
Catalytic converter
So i just recently removed my catalytic converters from my 2005 ford f150 2wd and been searching for new ones but the ones i come across aint available for delivery in California so i whas thinking can i use 4wd catalytic converters on my 2wd? I need sum help on that thank you.
if these are viable converters , I would drop ship them to a friend in a nearby state and get them shipped by them to me .or go pick them up . I can buy some chemicals locally at a high price but amazon won't ship them directly to me so I drop ship them .
Its not like you are not going to put cats back ..
I would also consider drop shipping them to a nearby state at a repair shop and drive over there and get it done. Canadians have to do this all the time.
Roader
07-27-2023 01:50 PM
Roader
06-12-2010 01:34 AM
