smoke switch
Old Mar 8, 2011 | 01:53 PM
alexisvfd's Avatar
alexisvfd
smoke switch
does anybody here no how to hook up a smoke switch on a 2004 250..
Old Mar 8, 2011 | 02:16 PM
2006powerstroke90's Avatar
2006powerstroke90
I know how to I am going to tell you its a BAD idea but its your truck do what you want.
Just tap into one of the wire that plug into the turbo, and put a switch. cheap way to get black smoke, but a real BAD way.
Old Mar 8, 2011 | 02:26 PM
alexisvfd's Avatar
alexisvfd
where does the other one go..does it go to just a ground..i tried it earlier but it just kept on shutting the turbo off
Old Mar 8, 2011 | 02:31 PM
Kert0307's Avatar
Kert0307
That's the point is it not... turbo off = over fueling = black smoke...
Old Mar 8, 2011 | 04:03 PM
alexisvfd's Avatar
alexisvfd
so do i need to just give it a few times to do it..i didnt do it right away
Old Mar 8, 2011 | 04:49 PM
rdunagan's Avatar
rdunagan
you might need a programmer to do it but idk. its not the best idea at all unless you have the money for a new turbo and stuff. you know a cheaper way than that though is just unplug the thing. then when your done plug it back in
Old Mar 8, 2011 | 06:04 PM
alexisvfd's Avatar
alexisvfd
What's the difference. I understand what your saying but isn't that what the switch is. Just cuts it on and off. How is it bad for it. I'm learning about all of this
Old Mar 8, 2011 | 06:16 PM
High Binder's Avatar
High Binder
LOL, this thread is going to be awesome! I kind of like the Turbo kill switch idea too. But if I were you I would drill and tap the intake manifold around the EGR (central-ish area) and rig up an auxiliary fuel tank attached to some for of injector like maybe a windshield wiper sprayer or something, then add a switch. I wouldn't do this to my own truck ever but it would smoke a lot and if you did it enough times you could get a brand new motor which is a cool side-effect...
Old Mar 8, 2011 | 06:24 PM
High Binder
You could add a nitrous wet kit without the nitrous... That's actually probably your best bet.
Old Mar 8, 2011 | 06:29 PM
alexisvfd's Avatar
alexisvfd
Ha Aight. This helps a lot. But why is it so bad on the turbo over time.
Old Mar 8, 2011 | 06:31 PM
TONKA05''s Avatar
TONKA05'
save your Ford dont try to make it smoke, down grade to a cummins and you can produce as much smoke as you can afford
Old Mar 8, 2011 | 06:35 PM
wulfman's Avatar
wulfman
This is a great thread we all need a turbo kill switch and nitrous and propane
Old Mar 8, 2011 | 06:40 PM
npccpartsman's Avatar
npccpartsman
There is more than one thread at the .Org about this ridiculous mod. It's a BAD thing for an already finicky turbo not to mention it being one more reason for the tree huggers to bitch and put MORE regulations and controls on our trucks. If you want to blow some smoke why don't you just shove a lit rag down your fuel tank neck. Then you can see some REAL smoke.
Old Mar 8, 2011 | 06:49 PM
69cj's Avatar
69cj
I completely agree with Tim. You bitch about all the EPA regs and then give them more fuel for the fire. You must also not have kids that you care about breathing all the c*** that you're putting out.
Old Mar 8, 2011 | 07:28 PM
alexisvfd's Avatar
alexisvfd
Yall are old timers. Yall were young at one time trying to have fun so chill out. If yall don't like it don't comment on it. thanks
