Sponsored by: Real Truck
Squilling problems
Old Mar 7, 2011 | 06:54 PM
Blue Monster's Avatar
Blue Monster
Squilling problems
I have a 2003 6.0 that has a squilling noise from the turbo area. I changed the turbo and it still makes the noise? And ideas on my possible problem?
Old Mar 7, 2011 | 06:57 PM
Bigpipes 35's Avatar
Bigpipes 35
Have you ruled out the belt and all the accessorys ?
Old Mar 7, 2011 | 07:01 PM
Blue Monster
Yes the belt was also changed and all the pullys are in good shape and spin freely. The only other thing i come up with would be a hole in the exhaust or something with the EGR valve i was told. I am realy at a loss!!!
Old Mar 7, 2011 | 07:55 PM
bayou barataria's Avatar
bayou barataria
You mean squealing?
Old Mar 7, 2011 | 08:12 PM
Blue Monster
Yea squealing!!! Im a horrible speller!!!
Old Mar 7, 2011 | 09:11 PM
FireMe's Avatar
FireMe
Very common for the up-pipes to crack at the flex portion of the pipe and whistle very loud. Might want to look closely at those. It can also be caused by a leak at the EGR cooler gasket at the up-pipe connection.
Old Mar 8, 2011 | 07:05 AM
Blue Monster
So I should get the egr delete pipe kit to fix both those problems??
Old Mar 8, 2011 | 07:02 PM
bayou barataria
On a 2003 I beilieve you can just unplug the egr valve, no need to delete, check out the 6.0 forum. My turbo went out 3 times on my 6.0 and it did not squeal, but you could hear the bearings it sounded like some thing rubbing on plastic when you let off the throttle.
truknut1972
25
Nov 22, 2010 02:10 PM
CounterMaker
Aug 19, 2009 05:39 PM
Dean88
Dec 17, 2007 10:56 AM
61 uni
Sep 30, 2007 08:21 PM
akmud
Sep 20, 2005 11:37 PM
