Sponsored by: Real Truck
2011 F250 Headlight question
Old Mar 7, 2011 | 11:00 AM
AussieCraig's Avatar
AussieCraig
Greetings Gents, I have a 2011 F250 Super Duty as a company vehicle and I wanted to improve the headlights. As its not technically mine I don't want to do much except change the bulbs out, can someone please recommend any alternatives that will practically improve night visibility?
Old Mar 7, 2011 | 06:49 PM
BIGKEV111's Avatar
BIGKEV111
I have the same question.
I have thought about switching the huge amber running lights above the headlight to a clear bulb?
Anybody got any ideas or done anything different?
Old Mar 7, 2011 | 07:14 PM
pbeering's Avatar
pbeering
Short of an HID or LED conversion, your only inexpensive option is a set of Sylvania Silverstars.
Old Mar 7, 2011 | 07:53 PM
bayou barataria's Avatar
bayou barataria
I moved the amber turn signal from the top socket to the middle amber one and installed hid lights in the top spot and hooked it up to the upfitter switches and they work like high beams. If you are careful you can leave the running lights in the middle spot and still add the turn signal.
Old Mar 7, 2011 | 08:08 PM
Rick Cargo's Avatar
Rick Cargo
I put Sylvanvia Silverstars in mine and it made a big difference.
Old Mar 7, 2011 | 08:40 PM
PsycoJuana's Avatar
PsycoJuana
sweet deal guys i too was wondering about this
Old Mar 7, 2011 | 08:43 PM
FredsTow's Avatar
FredsTow
Silverstars
I have put Silverstars in all of my trucks and in comparison to HID conversions they are the most cost effective and make an amazing difference!
Old Mar 7, 2011 | 08:58 PM
swengle's Avatar
swengle
H13 lamps for the 2011 Super Duty - right? Think also known as a 9008? Specifically Sylvania Silverstar H13ST?
Steve
Old Mar 7, 2011 | 09:39 PM
Rick Cargo's Avatar
Rick Cargo
Steve, I used used the Slyvania H13(9008) silverstar lamps. From what I understand Sylvania has not made a Ultra-Star lamp for this model yet. Rick
Old Mar 8, 2011 | 09:45 AM
2000silverbullet's Avatar
2000silverbullet
Check here:
https://www.ford-trucks.com/forums/9...id-lights.html
More options can be found by searching "headlight" in the 6.7 forum.
Old Mar 8, 2011 | 11:52 AM
iggy2's Avatar
iggy2
Sylvania Silverstar H13 bulb review
These bulbs are slightly brighter than the factory equipped Sylvania Standard H13s.
Many like the tinted SilverStars tend to fool the human eye into thinking that the whiter light is brighter (especially in a dark environment like an unlit highway) while in reality the yellower lights tend to get picked up more readily by the human eye and are brighter.
The OEM bulb is a Long Life 9008/H13 bulbs from the factory. Long Life usually means the bulbs were designed with filaments and gas mixtures designed to extend the duration at which the light output remains usable, approximately 800-1300 hours in a laboratory environment.
Sylvania does not keep it a secret that their SilverStar and SilverStar Ultra line of headlights are not designed for longevity. According to Sylvania for their 9007s, their SilverStar lasts 150 hours, the SilverStar Ultra lasts 200 hours, while the XtraVision lasts 375 hours. The 9008/H13 standard bulb can go up to 1000 hours, while the Sylvania SilverStar 9008/H13 is rated at only 325 hours and the 9008/H13 XtraVision is rated for 500 hours.
In the SilverStars, the gas mixture and filaments were designed to compensate for the loss of light transmission from the filter (tint) on the bulb glass. The SilverStars are essentially "ricer" bulbs designed to make the color temperature appear near 4000K (HID white) but this costs you lifespan.
The 9008/H13 XtraVisions are rated for about 500 hours and do not have any lens filters to change the light color. 500 hours is on the short side of the OEM Long Life spec but it is a good balance of lighting power and lifespan. From my experience, they will last at least 3-4 years of normal use (about 30 minutes every workday). Daytime Running Lights and automatic headlights SEVERELY reduce bulb lifespan because they keep the bulbs running at full voltage whenever you use the car contrary to popular belief. In addition, headlight bulbs are rated at 12.8 VDC, which means that the 800 hours was obtained from testing at 12.8 VDC. Running the bulbs at a higher voltage, like the 14.0 VDC that most charging systems produce, will dramatically reduce bulb life. So this is not a surprise that SilverStar owners are getting 3-6 months of use out of their bulbs.
I have used XtraVisions on 3 different cars over the past 7 years and have the utmost confidence in the lighting power. They are still halogens and produce a 3200K "white", but there is a DRAMATIC difference from factory Standard or Long Life 9008/H13s. They make all reflective objects light up, and I can see a bit farther down the road. I've tested GE Nighthawk 9008/H13s and they produce a slightly whiter light with about the same light output, so either the XtraVision or GE Nighthawk 9008/H13s are the best halogen upgrade.
The ultimate lighting solution would be a street-legal HID upgrade, which is cost prohibitive for most owners and requires a lot of work to install. The next best thing would be XtraVision bulbs.
Pros: The best bulb upgrade you can get with a decent lifespan (about 800 hours). Totally street legal, and a big improvement over Standard or LL bulbs. Can be purchased at discount prices.
Cons: Still produces a 3200K halogen "white" which is yellow compared to HIDs. Confusing marketing causes most people to buy SilverStar / Ultra bulbs instead.
Overall: 5/5 stars for what it is: affordable upgrade for existing lighting.
Old Mar 8, 2011 | 01:00 PM
MuncieV10's Avatar
MuncieV10
iggy2,
Thanks for a great explanation of the differences in these replacement bulbs; I've often wondered if they were worth the effort to replace the factory bulbs.
I do have the factory HID lights on my car; in my opinion they are not that much better than factory Halogen bulbs on my truck and do not warrant the huge difference in price.
Mike
Old Mar 8, 2011 | 07:07 PM
bayou barataria
I tried the sylvania bulbs, they just put a blue tint on the bulb it did not make much of a difference to me that's why I went with the hid kits. You can pick up a kit on e-bay for less than a hundred bucks now. Make sure you get one with the isolating relay or they will flicker from the truck computer. I got the one with high beam hid and low beam halogen for when you can't use the hid. P.S. the 6000k temp. is the white color for those who don't like the blue like the kids have.
chrislambing
Oct 31, 2018 09:55 AM
mojavearcher
Jan 20, 2017 09:41 AM
snirt-racing
Dec 31, 2016 07:39 PM
09f250v10
Apr 14, 2016 07:18 AM
bdarr4014
6.7L Power Stroke Diesel
Dec 29, 2011 06:54 AM
