Smog Pump
Old Oct 11, 2010 | 08:02 PM
truknut1972's Avatar
truknut1972
Smog Pump
I have a 92 F150 w/ 302, E4OD, 3:55. I don't have the cats anymore, now my smog pump is starting to squill and it's got to go. So what size belt do I need or is something else I can do. Thanks, Jeff.
Old Oct 11, 2010 | 10:50 PM
polarismuddman's Avatar
polarismuddman
They make a smog pump eliminator pulley available from summit......
Old Oct 12, 2010 | 01:46 AM
TexasGuy001's Avatar
TexasGuy001
The smog pump doesn't take that much to turn. It seem to me it would be better to just get a shorter belt. Maybe I'm missing something, but I don't see the need for an eliminator pulley.
Old Oct 12, 2010 | 01:57 AM
zombie_killer's Avatar
zombie_killer
The last numbers in a belt part number are its length (if you were to cut it and lay it out from end to end). For instance, mine is K050990. K05 means 5 ribs, 0990 means 990mm. Hope this helps you out.
Old Oct 12, 2010 | 11:35 PM
truknut1972
Thanks everyone. Zombie do u still have your smog pump?
Old Oct 13, 2010 | 12:47 AM
polarismuddman
The point for the eliminator pulley would be that you can't just throw a shorter belt on there to bypass the smog pulley like you can on a 351. The 302 belt routing won't allow it... Been there, tried that.
Old Oct 13, 2010 | 01:47 AM
Dirt racer's Avatar
Dirt racer
I took my smog pump off my 92 F150 with a 302. I am running a Gates belt K060876. 13/16" X 88 1/8" OC. It was a little on the tight side. Been on there over a year now and still working great.
Old Oct 13, 2010 | 02:49 AM
cjben's Avatar
cjben
I used a Goodyear Gatorback 4060915 on my 95 5.0,been that way for almost a year,no problems.
Old Oct 14, 2010 | 01:36 AM
TexasGuy001
The belt routing is different between 302 and 351? I remember them being the same.
Old Oct 14, 2010 | 07:00 AM
lew52's Avatar
lew52
You don't need the eliminator pulley , but they cut down the distance from the crank to the other accsories & help the belt run true at higher rpms , i use one on my truck ....Lew
Old Oct 14, 2010 | 10:23 AM
polarismuddman
Some of the belt routing stickers do indicate them as the same but on some years (don't remember what I know fer sure 94) the tensioner is in a completely different spot.
Old Oct 15, 2010 | 09:22 PM
truknut1972
Dirt racer and cjben and lew52 are ya'll running a elimanator, or you did you just take the pump off?
Old Oct 16, 2010 | 01:01 AM
cjben's Avatar
cjben
I just bypassed the pump,haven't taken it off yet,it is just sitting there.
Old Oct 16, 2010 | 06:14 AM
lew52's Avatar
lew52
I removed the pump & used a FR eliminator pulley...Lew
Old Nov 20, 2010 | 05:13 PM
truknut1972
Well I bought the 4060915 belt that cjben suggested but its longer than my factory belt. 4060910 is the Gates #. I even called Summit they said they don't carry a SP elimator for the F150 only the mustangs. So what do I do now? Thanks.
