wiper cowl issues
Old Mar 8, 2011 | 07:06 PM
the4by4freek's Avatar
the4by4freek
I am the one that came up with the screw fix. This has been installed for almost 6 years and it hasn't rusted or popped loose yet. Use a stainless steel screw and it won't rust. This is the easiest, cheapest, fastest fix I have seen. My cowl does still rattle against the windshield.... I plan on removing it and placing a bead of silicone on the back side and then re-installing. This should solve that issue also. When I do this, I will take pictures and post them.
Old Mar 9, 2011 | 08:40 AM
snowdog79's Avatar
snowdog79
I have to do something about the cowl/windshield rubbing too.
Old Mar 9, 2011 | 09:31 AM
the4by4freek
I just went out and tried a simple fix. I removed the entire cowl and found that Ford has installed a rubber weatherstrip under the cowl where it meets the windshield. It was slid down away from the edge and the cowl was rubbing the glass. The weatherstrip was also a little deteriorated. I removed all of the old weatherstrip and installed a new piece that actually has adhesive on both sides.
I re-installed it and then pulled the protective cover off the adhesive and stuck it to the glass. I have yet to take it for a ride to see if that solved the issue. I will post back when I find out.
Old Mar 9, 2011 | 08:24 PM
the4by4freek
Ok.... I think I may have found the fix for the rubbing cowl..... I will know more tomorrow. I will tell you that I have had the truck up to 70MPH and approximately 98% of the rattling is gone!
Old Mar 10, 2011 | 05:20 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
6 months after I bought my truck the cowl popped up.I took it to my local Ford dealer and they fixed it.Thats been over 3-1/2 years ago and it is still in place!
Old Mar 10, 2011 | 10:06 PM
the4by4freek
Consider yourself lucky! WHEN it does pop loose, put the screw in it.
Old Mar 10, 2011 | 10:21 PM
snowdog79's Avatar
snowdog79
the4by4freek, what did you use/where did you get the weatherstrip you used for the cowl?
Old Mar 10, 2011 | 10:49 PM
BlueOvalFitter
I don't think it will.
TexasGuy001
24
Aug 29, 2022 10:49 AM
rizob01
May 22, 2017 05:50 PM
burninrubber2416
2004 - 2008 F150
26
Mar 7, 2016 06:34 PM
DGMFORD
2004 - 2008 F150
Dec 8, 2011 08:25 AM
xc4jokestomper
Feb 20, 2011 11:42 AM
