wiper cowl issues
Old Mar 7, 2011 | 09:21 AM
madmann's Avatar
madmann
wiper cowl issues
07 150 4x4 supercrew. the damn wiper cowl keeps poping up in the center, then it seems I get ice under the edge and against the window, and she sits and growels at me at hwy speeds. like someone is rolling a golfball around and around and around...etc. any solutions or better aftermarket parts??????
tired of small issues and cheap parts
Old Mar 7, 2011 | 09:27 AM
bogeyrider63's Avatar
bogeyrider63
Trailering
had dealer fix mine per tsb and that only lasted 1 year and it popped again. reading on another f150 site that guy's are using a #8 1/2 inch stainless steel self tapping screw.
Old Mar 7, 2011 | 11:19 AM
madmann's Avatar
madmann
Little late for the screw, I gave it a wack and its now broken.
Cant wate to purchace another one that wont work either.
Old Mar 7, 2011 | 12:02 PM
jimmyv13's Avatar
jimmyv13
Yeah, the new one you get won't stay put either.....the screw is the only real fix.
Old Mar 7, 2011 | 12:47 PM
madmann's Avatar
madmann
Are there any aftermarket ones out there to replace the oem p.o.s
Old Mar 7, 2011 | 01:49 PM
Steve_Uzi's Avatar
Steve_Uzi
Mine is cracked... and the clip is gone! It is still in one piece so I might try to shore it up from underneath. Then I will use Stainless steel screws to hold it in place
Old Mar 7, 2011 | 01:53 PM
jimmyv13's Avatar
jimmyv13
Here's one from streetscene. Pics suck, but that's all I could find.
Old Mar 7, 2011 | 04:31 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
Only need 1 screw in center where the 2 pieces join
If you search on this site there used to be a post with pics.on how to fix it
Did mine 3 years now no problems.
Old Mar 7, 2011 | 05:56 PM
danorules's Avatar
danorules
all i did was drill 2 small holes on the passanger side cowl( just the plastic)then i used 2 tiny black zip-ties. you dont even see it unless you are really looking
Old Mar 7, 2011 | 07:05 PM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
Please post pics of this Mod!.........
Old Mar 7, 2011 | 07:47 PM
danorules's Avatar
danorules
i dont believe i would call it a "mod", it is just zipties.but when the sun comes back out i will snap some photos and post. it is real simple and you shouldnt them. from the pass. side i drilled the 2 holes towards the driver side 1/16th or 1/8th" bit.then i put the ziptie through the grids on the drivers side cowl, closest possible spots to the new holes i drilled, then snaked them through the drilled holes and tightened them down and cut off the loose ends. super easy to do. and doesnt add a screw to the front end to possibly rust later. pics will be up soon
Old Mar 8, 2011 | 04:45 AM
RISUPERCREWMAN
Thanks! Looking forward to them!
Old Mar 8, 2011 | 09:06 AM
snowdog79's Avatar
snowdog79
I stainless screw in the middle fixed the problem 3 years ago. I think it took 30 seconds.
Old Mar 8, 2011 | 09:22 AM
jimmyv13's Avatar
jimmyv13
That 30sec included opening a beverage and turning on the radio.
Old Mar 8, 2011 | 05:43 PM
V10man's Avatar
V10man
My truck has the same issue. Also, the rubber ends on both pieces is rotted. I wonder if I get another one from Ford if it will be the newer design.
