300 serpentine belt conversion ??
Old Mar 6, 2011 | 11:04 PM
krazylegswp's Avatar
krazylegswp
anyone done a conversion on a 300 i6 motor
Old Mar 7, 2011 | 07:44 AM
AbandonedBronco's Avatar
AbandonedBronco
I remember someone did it over on Ford Six Performance Home/Index. I think they just switched all the pulleys over. The other point of consideration is that you'd need a serpentine style water pump, since they rotate the opposite direction.
Old Mar 7, 2011 | 03:40 PM
Nitesaber's Avatar
Nitesaber
Why would you serpentine an I6? just puts more strain turning a tighter belt? unless its just for looks?
Old Mar 8, 2011 | 12:13 AM
krazylegswp
ive thrown two belts in the last month the just wont stay on
Old Mar 8, 2011 | 12:53 AM
krazylegswp
ive been reading some other forums and it looks like in some of the later years the started putting serpentine belts on like e250s and vans with 300 i6 motors i wonder if those will work
Old Mar 8, 2011 | 01:28 AM
jem44357's Avatar
jem44357
I plan on using the serpentine system from my '93 F150 4.9l donor on my 75 300 in my Roadster. I will be watching this thread.
Old Mar 8, 2011 | 06:39 AM
AbandonedBronco
Serpentine belts also have a lot more grip, which is why the serpentine belt setup has one belt, whereas the non has two belts for the alternator.
The downside is, if you throw a belt, you pretty much lose everything.
Old Mar 8, 2011 | 01:22 PM
Harte3's Avatar
Harte3
If you are throwing belts there is something causing this. Pulley wear and alignment?
Old Mar 8, 2011 | 03:46 PM
Nitesaber's Avatar
Nitesaber
I already had it on mine why i never really realized and took time to learn what it was. Thx
Old Mar 8, 2011 | 11:44 PM
krazylegswp
well im going to the junkyard tomorrow to see if they have the parts ill keep everyone up to date on what im doing
the reason for throwing belts is high rpms and bumps when playin out in a field lol
EvinrudeDude300
23
Mar 3, 2025 12:28 AM
Memphis_Sean
30
Mar 20, 2014 08:45 PM
dustman
Nov 27, 2011 07:37 PM
karljay
15
Nov 21, 2004 10:03 AM
paulg
Apr 18, 2001 08:27 PM
