new vehicle problem
Old Mar 6, 2011 | 08:17 PM
Lil Red Sled's Avatar
Lil Red Sled
new vehicle problem
Just got an 89 7.3 diesel. Oil pressure gauge doesn't work because of some wiring issues. Im putting in an after market gauge where can I put it without taking out the stock sending unit? Someone told me you can put it in another place on top of the motor. Anyone know where?
Old Mar 6, 2011 | 09:03 PM
farmert's Avatar
farmert
The way I would do it, is to get a1//8 pipe T and a short nipple. Remove the stock sending unit, screw the nipple into the T, then screw the other end of the nipple into the place you removed the stock unit. Then screw the stock unit into one open port of the T and the new gauge into the other port .
Old Mar 6, 2011 | 09:42 PM
Lil Red Sled
Is there a different location without touching the stock setup?
Old Mar 6, 2011 | 11:31 PM
84-6.9L's Avatar
84-6.9L
with all the fittings and some teflon tape it should take you about 10 min and keep both senders
Old Mar 6, 2011 | 11:34 PM
Country_boy_2007's Avatar
Country_boy_2007
theres some pipe plugs behind the oil cooler but its much easer to tee into the stock sender, thats what i did.
Old Mar 6, 2011 | 11:59 PM
GHeTTo JOe's Avatar
GHeTTo JOe
where is stock oil pressure location
Old Mar 7, 2011 | 12:41 AM
84-6.9L's Avatar
84-6.9L
behind the valley pan on the right side. heres a pic from another post
John D in CT
Mar 15, 2012 09:14 PM
Grizzle33
Aug 30, 2009 02:10 PM
Sparkplugless
May 29, 2009 01:31 AM
7278ford
1978 - 1996 Big Bronco
Apr 30, 2009 07:26 PM
PatrickMcD
Oct 28, 2003 03:25 PM
