We've had a similar discussion on the past. The general discussion was with the exception of some very specific service type vehicles (think airport) nobody has ever seem a short wheel base F250. But if you're cab says F250 and your title says F100, you've got a problem. Probably someone grafted the F250 cab onto your truck. What is the VIN on the cab?
It's either an F100 or F150 underneath. Two measurments that might help narrow it down are the wheel lug spacing and rear leaf spring widths. If you have 5 x 4.5 inches wheels, it's an F100. If the spacing is 5 x 5.5 inches its likely an F150. Spring width on the F100 is generally 2.5 inches, but it can be bigger, If the spring width is 3 inches its most likely an F150.
