working truck(s)
Thats just over 13k of 2-4" quary spalls in the box, max I have had back therre is 17,100 lbs, although normally it ranges from 12 to 14k.
41 years and still working hard!
David
<a href="http://s638.photobucket.com/albums/uu107/dmanlyr/?action=view&current=babeatwork.jpg" target="_blank"><img src="http://i638.photobucket.com/albums/uu107/dmanlyr/babeatwork.jpg" border="0" alt="Photobucket"></a>
And the other side
The second photo is when I bought it. Thats the for sale sign in it. David
David
The Bad was the shifter went from the Dashboard to the seat when shifting it lol, No power steering,,,But I do miss that ole Girl,,,,,Memories,,,,,Them 391's Ran !!
Of course that 111" wheelbase and p/s does make tight areas more comfortable.
David
I never really heard of a 330 (aside from the 5.4L modular). Can you tell me more about this engine? Bore, stroke? What power at what RPM?
If you don't I completely understand, I'm just a freak about this stuff.
- Bill
It is a FT engine, same basic engines as the 361's and 391's. Off shoot of the FE engines
The 330's were available in two versions, regular and HD. The 361's & 391's were all HD
the 330's have a smaller bore than the 361, same stroke. The 361's and 391's share the same bore, but the 391's are a longer stroke.
330's were 2 barrels, 361's were either two or four barrel and the 391's were all four barrel.
As to FT & FE differences - The heads, intake manifold and exhaust manifolds are unique to the FT versions, the FT's also have a larger crank snout / balancer. The FT engines also are set up with a considerably lower compression ratio to be able to slog fully loaded up a hill without detonation/knocking/pinging. There are more differences, but these are the highlights.
According the my 1970 factory manual, the FT engines are also set up to run richer (13:1) from the factory in comparison to say the 390 at closer to a 14.5:1 air fuel ratio.
You may already know this, so hopefully I am not being too long winded - I am a nut for specs, and figuring out why the factory builds/engineeres things the way they do! Especially when it comes to medium trucks, where the duty cycle is at a much higher continuous load than the average light truck.
FYI - I have a mid 70's brochure of 18 pages on the "XD" engines that these "HD" engines morphed into, very imformative right down to the different types of piston rings used in the different size and rated engines!
Thank for asking, David - EDIT! Next post I will post hp and rpm's / bore & stroke - I reread what you posted and realized I had not answered that!
If anyone is interested in the rest of the publication - I can scan it, as long as I am not breaking any copyright laws!
I'm really glad to know you're a nut for specs too. I'm the same way. I just recently purchased a large automobile book that has cars back from the 20's to the 2000's I think. It lists bore and stroke, copression ratio, RPM's, all the good stuff us spec nuts love to take in to see what makes an engine do what it does!
I would love to see the brochoure (sp). If it isn't too much trouble, by all means post it!
By the way, I guess I've been left out. I never heard of a 361 or 391. I know of the beloved 360 and workhorse 390. I guess because I've never had any experience with the HEAVY heavy duty trucks I've been missing out on a whole new slew of powerplants to learn about.
You know, I'm very surprised. I had no idea such a relitively small engine could move so much weight. Honestly I thought trucks your size absolutely had to have BIG diesel engines.
- Bill
As for the 330 MD vs. HD, the 330MD had the FE-size crank snout, and I think used the standard cast crank, while the 330HD had the FT size crank snout and steel crank.
Now I have to go over to the transit connect section, and ask a few questions, but not until I get the XD book scanned and posted!
The 300HD six which as you might guess is a offshoot of the usual 300 six found in pickups.
I am unsure if they came in anything bigger.
