Injector cups??
Old Mar 6, 2011 | 07:17 AM
91 Dually's Avatar
91 Dually
Injector cups??
97 f350 powerstroke slightly overheated while driving. Discovered antifreeze level was low. Got her cooled down. Topped off antifreeze. Drove home and parked. Next day engine wouldn't crank. Pulled valve covers, removed glowplugs. Cranked engine and water blew out one cylinder. Signs of water in oil and oil in water. A local mechanic says it's likely a bad or leaking injector cup. Agree?? / Disagree?? Any thoughts?
Thanks, Brian
Old Mar 6, 2011 | 07:56 AM
rideracelivemx7's Avatar
rideracelivemx7
Well if I remember correctly when an injector cup cracks it will introduce fuel and or oil int the water system because they are a higher pressure. Now when you have water in a cylinder that's leading me to think that's a head gasket issue, but you can run a few tests I'm sure to be pointed in the right direction. Id first start off by running it for 5 minutes to see if the bottle is pressurized
Old Mar 6, 2011 | 08:03 AM
427 fordman's Avatar
427 fordman
I don't know if I'd be running it if there is water in a cylinder. I'll let more experts chime in as how to diagnose this. Doesn't sound real good to me though, could be head gasket like steve mentioned.
Old Mar 6, 2011 | 08:04 AM
91 Dually's Avatar
91 Dually
Bottle was not pressurized. Only normal cooling system pressure. BTW I already rebuilt the oil cooler a couple months ago, so pretty sure oil not coming from there.
Old Mar 6, 2011 | 08:08 AM
rideracelivemx7
Well after a cold start and ran for a few minutes will determine if the head gasket is junk. But if it's not and it fills a cylinder when the trucks off then the pressure from the hot system while off I'd agree to being a bad injector cup
Old Mar 6, 2011 | 08:24 AM
91 Dually's Avatar
91 Dually
Also......Where would be a good place to buy injector cups. And now would be a good time to upgrade injectors..Any suggestions as to where to buy a set of stage ones?
Old Mar 6, 2011 | 08:30 AM
rideracelivemx7
Jim has everything you need to do that project, not sure if he still has the cup tool anymore. Shoot him a pm, the most expensive part is buying the tool, the cups are dirt cheap
Old Mar 6, 2011 | 11:17 AM
Ken_C's Avatar
Ken_C
last I heard he will loan you the cup tool by mail. ask him i think he still does that.
Old Mar 6, 2011 | 12:21 PM
tjbeggs's Avatar
tjbeggs
Best way in my opinion would be to pull the injector in the hole that had coolant in it and look for coolant at the cup. If you don't see any pressurize the cooling system. And see if you can see where its coming from.
Old Mar 6, 2011 | 07:54 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
I agree with that.
I've been reading alot on the 6.0l powerstroke as I have one torn down on an engine stand and I remember reading the prefered way to check injector cups is to drain the coolant and pressurize the cooling system with regulated air and then spray down the injector cup with a soap water solution and see if bubles appear. I'm guessing air seeps out of a crack more so then a fluid. Like said, referenced from the 6.0L powerstroke.......
Or I guess you can pull out all the glow plugs, fill up the anti-freeze, pressurize the system over night and slowly turn it over the next morning by hand to see if coolant pushes out of the glowplug hole if enought has leaked out. If you find that then heads come off and get them checked for cracks and headgasket job.
With coolant in your oil, I'll lean to headgaskets/cracked head.
Old Mar 7, 2011 | 08:13 AM
Action4478's Avatar
Action4478
Though it would be a simple test to check the cup ,I have never heard of a cracked cup leaking into a cylinder . If it were deformed enough, it may leak past the injector tip .The cups are surrounded by coolant in the head . If you do a compression leak down test , you can pinpoint where the leak is by listening where the air leaks out (exhaust, intake ,c case ,or cooling system ....
Old Mar 7, 2011 | 11:31 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The copper washer on the bottom of the inejctor does a great job of sealing the injector and cup from the cylinder. Basically, the bottom edge of the sleeve is pinched between the cast cylinder head and the injector, sealed up with the copper washer on the injector tip.
I simply can't see how coolant would get from the sleeve into the cylinder, unless you are missing the copper washer AND the sleeve blew.
My vote is bad head gasket or cracked head.
I like Tim's suggestion. Pressureize the cooling system (don't drain it, keep the coolant there) and inspect all the sleeves. If you find water in the cylinder after doing this, but none comes from the sleeves, I guess that tells you where to look.
Good luck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
60'_f100
Jul 5, 2017 11:19 AM
Ryan313
34
Apr 28, 2017 08:13 AM
RV_Tech
Feb 28, 2016 02:48 PM
Shaneb75
Mar 18, 2012 05:29 PM
frogcookietater1
25
Feb 12, 2012 10:34 PM
