where is engine s/n
Old Mar 5, 2011 | 10:01 AM
429 f-100's Avatar
429 f-100
where is engine s/n
where is the engine s/n on a e99 7.3 ?
Old Mar 5, 2011 | 10:02 AM
bulla's Avatar
bulla
Or any 7.3 for that case?
Old Mar 5, 2011 | 10:14 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Look next to the oil filter.
Old Mar 5, 2011 | 10:38 AM
429 f-100's Avatar
429 f-100
the number on the rear oil cooler brkt? that the only one i see i think that is right i see 1815739c2
Old Mar 5, 2011 | 10:48 AM
PaysonPSD's Avatar
PaysonPSD
It should be on the block next to the bracket.
That's an INTL part number.
If you have the stock VCs the driver side should have the sticker with serial number and engine build date.
Old Mar 5, 2011 | 10:56 AM
429 f-100's Avatar
429 f-100
thanks robin i tried to read that decal even with a mirror i coulndt see it all thought i would ask before movin the tube out of the way. i didnt see any numbers onthe block im gonna look agian and move the tube now.
Old Mar 5, 2011 | 11:39 AM
PaysonPSD's Avatar
PaysonPSD
I had to use a wire brush to reveal the S/N on the block.
Here's a pic of S/N running vertically on block with VC sticker superimposed.
You will also find the last 8 digits of the vin number running horizontally.
Old Mar 5, 2011 | 11:42 AM
SpringerPop's Avatar
SpringerPop
See this thread for photos:
https://www.ford-trucks.com/forums/1...ml#post9548266
Oooops! Robin's got you very well-covered!
As always, a very comprehensive answer from him!
This isn't for a truck whose VIN begins with a "3", is it? The engines for those trucks were made in Brazil, and have a different range of numbers assigned to them.
Pop
Old Mar 5, 2011 | 11:45 AM
429 f-100's Avatar
429 f-100
You will also find the last 8 digits of the vin number running hotizontally.
awsome pics robin !! im gonna go scrape mine now thanks !!
Old Mar 5, 2011 | 12:18 PM
woodnthings's Avatar
woodnthings
I have noticed that the engines built in Brazil have a much lighter engraving. They all start a 5 in the S/N.
Old Mar 5, 2011 | 12:35 PM
429 f-100's Avatar
429 f-100
Pop[/quote]
no sir pop it begins with a 1 . my engine # is783810 // i was trying to figure out if the epv rebuild kit i got fro clay will fit i have the hourglass shaped pedestal and i was reading that it might not fit. thanks guys wes
95PSDieselP
Sep 10, 2010 04:39 PM
dmphillips5578
1947 and Older Ford Trucks
Sep 9, 2009 02:58 PM
Bullet 1
Oct 19, 2005 07:32 AM
Skeetshooter
Nov 5, 2003 07:55 PM
AmeriKen
Apr 17, 2003 02:52 PM
