hi got a 390 2v in a 350 dump 1979 can i jet some specs on this eng. its not running right it pops & some times it stalls at a stop & drinks gas bad. thanks .
sure thing what kind of details can you help me idenify my eng it says 390 2v on air brether not sure thow its a 79f350 thought they stop making 390 in 76 not sure not sure bought much thanks for your help its 4 speed on the floor.like to idenify that also its got pto for dump that works 12/ bed thanks again.
Nope, sorry. FE/FT are notorious for being hard to identify. As externally all FE's (besides the SOHC) look exactly the same. Same goes for FTs. Casting numbers are a very vague guide as the same # was used for different displacements.
thanks sleepy&bucks took some pic today trying to get thim from laptop 2 this forum soon maby u can tell me somthing from pic it has motor mounts back abought 1 foot or so from front. deep oilpan up front fule pump front driver side does fule pump work off timming chang oil filter same side up front thanks
Here's how to post pictures: one way that is.....
1. Log in to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time. There is a size limit to the pics you upload. I think it's 800x600 pixels. If you need to resize an image on your computer, you can right click it and open in paint, then click resize and type in the pixels, save and you're ready to upload)
6. Click Upload.
7. Add a description to the individual pictures if you want, then click save.
8. Add more files if ya want.
9. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If that doesnt work for whatever reason you'll need a image hosting site like photobucket. Load them there and then copy and paste the IMG code at the bottom of the pics.
You have to click the "Go Advanced" next to the "Post Quick Reply" by the way to be able to add links and pics.
May be wrong but the main difference was the flywheel and a few minor things. The 390 can be an awsome engine if "built" right. Consider the 390 CAR engines. I don't think you're ready to put a 390 Cobra Jet in the truck. Many stock and aftermarket parts are available.
got to look at the truck today on the hood its a 400 not sure on intake d3te9425aia carb motorcraft d4ae c 3k 11 ga on tag my [79 351m oil filter is on 45* & what ever is in my79f350 is straight up & down my oil filter] hope that helps allso can I take my holly 4bl off my 351m put it on my f350 what do u all think thanks .
