1978 - 1996 Big Bronco
Which grease for window regulator?
Old Mar 4, 2011 | 06:30 AM
b4hntn's Avatar
b4hntn
Fixing the passenger window regulator is on my roundtuitt list. I bought the Help! kit with the three nylon cylinders. What grease would be best to use in the gears?
Old Mar 4, 2011 | 09:49 AM
AbandonedBronco's Avatar
AbandonedBronco
I did mine a few weekends ago and just used some multi-purpose automotive grease.
It made such a difference. I could turn the window crank with the tip of my finger.
The one thing to keep in mind when greasing it up is to grease the flat, broad sides of the gears, since they do slide along each other.
Old Mar 4, 2011 | 10:33 AM
b4hntn's Avatar
b4hntn
Thanks. I forgot to mention mine are electric but, I was thinking chassis lube for it also after cleaning out the gear box.
Old Mar 4, 2011 | 10:37 AM
AbandonedBronco
It should still be the same. As far as I know, the motor just spins what the hand crank would spin. All the regulators and gears are the same.
Yeah, that's probably the same thing. Chassis, wheel bearing, multi-purpose grease.
Just be ready for your cab to be a little "strong" smelling for a few weeks.
Old Mar 4, 2011 | 10:45 AM
greystreak92's Avatar
greystreak92
Personally, I don't lube those parts with anything petroleum based that stays put for long. The environment inside the tailgate is one of dust and road debris that comes up through the drain holes and down on the surface of the glass each time its raised and lowered. Dust/dirt and oil or grease is a recipe for sticky mechanisms. Graphite the heck out of it. I use a product that unfortunately cannot be purchased anymore but can be mixed. It consists of a very light (I'm talking sewing machine) oil mixed two-to-one with powdered graphite. The oil is light enough that it dries up quickly and leaves the graphite behind. Since the oil will wick into the crevices, it carries the graphite deeper into the mechanism than it could get on its own. The mixture will not remain blended for more than a few hours so if you have any left over you will have to shake it thoroughly to use it again later.
Old Mar 4, 2011 | 10:52 AM
b4hntn's Avatar
b4hntn
Thanks gs. Too late on the tailgate. I did it last year with wheel bearing grease. Do you suggest your mix in the worm gears of the passenger window?
Old Mar 5, 2011 | 12:48 AM
greystreak92
In a sealed gear-head I wouldn't worry about dust contamination as much but any location that has components bearing on each other and exposure to the elements is possible, I use "lamphouse" lube. (Which is what the stuff I mentioned above is called in the industry it was employed.)
Huntington
Sep 30, 2020 02:09 PM
Cruiseomatic
Electrical Systems/Wiring
Nov 16, 2016 10:45 AM
Daniels54
Oct 14, 2016 08:34 PM
bbygirl778
Oct 3, 2015 02:42 AM
tassmannn
Aug 28, 2014 07:38 PM
