oil leak PSD
Old Mar 14, 2003 | 05:42 AM
beaboarder's Avatar
beaboarder
oil leak PSD
I have a 2002 PSD with 20,900 miles, I have noticed a small amount of oil coming from the bottom of the starter housing (not enough to drip).Any idea's what the cause could be, should I have it checked out ?
Old Mar 14, 2003 | 07:52 AM
powerstroker250's Avatar
powerstroker250
oil leak PSD
Check the top of the engine to see if the oil is coming from there. Most leaks occur here. Since you are under warranty let the dealer handle it.
Les
Old Mar 14, 2003 | 11:42 AM
DL's Avatar
DL
oil leak PSD
hey beaborder this is ironic as ever. I have an 01 stroker with 29,000 on it an just 2 days ago i notice a leak in the same exact spot. There is oil from the starter running over to some sort of cover panel on the bottom of the bell housing/transmission area. Im not a mechanic and couldnt tell if it was coming from above the starter (couldnt see). Mine goes in to the dealer on 3/23. If you or anyone out there had the same problem let me know what your fix was.
later.
Old Mar 15, 2003 | 06:27 AM
xanthias's Avatar
xanthias
oil leak PSD
We discussed the same issue here:
https://www.ford-trucks.com/forums/s...hreadid=101919
Have your dealer put in some dye. The day I went in, they were out of dye! (go figure). Heading back in the next few days.
WarOzz
15
Sep 20, 2010 12:47 PM
kupiec20
May 18, 2008 08:22 PM
TreeFarmer05
Dec 22, 2005 05:19 PM
06f250fx4
Aug 30, 2005 02:17 PM
alm911
Dec 22, 2003 11:39 PM
