damn thing wont start
Old Mar 3, 2011 | 07:02 PM
92nite351's Avatar
92nite351
so monday i went to leave work to head home and it wouldnt start... so i replaced the starter first cuz the battery had plenty of juice, still no start. so i replaced the battery anyway just in case... still no start. i jumped the thing and and it started and ran for a few. i thought all was well, went outside and it wouldnt start again. plenty of gas, silinoid is new, battery is new and starter is new. when u turn the key it just clicks, but like i said the battery is new and so is the starter.... if u need more info just let me know. thanks
Old Mar 3, 2011 | 07:18 PM
fdude64's Avatar
fdude64
I know this might sound stupid "but" did you clean the battery cables and check the ground at the block? just asking
Old Mar 3, 2011 | 07:25 PM
92nite351's Avatar
92nite351
yup i checked the ground straps, and cleaned the terminals. the top blot was broke off, so the bottom bolt was the only one that was tight, i used a small C clamp to hold the top of the starter tight. could the starter not be in totaly right? could it be turned just a little bit? thus causing the bendix to not act properly?
Old Mar 3, 2011 | 07:34 PM
BRay09's Avatar
BRay09
when you say the selinoid is new, do you mean the on eon the starter itself or the starter selinoid on the fender? Is that properly grounded to the fender as well?
Old Mar 3, 2011 | 07:45 PM
92nite351's Avatar
92nite351
yeah everything is grounded well, i changed the other stuff last weekend, the starter and battery were changed today. it ran fine up till this point. even with battery charger in start position it would only click.
Old Mar 3, 2011 | 07:56 PM
DBGrif91's Avatar
DBGrif91
What's the condition of the battery cables? Cut a small piece of insulation off each cable- if the strands are dark, the cables are bad and need to be replaced.
I don't know if your truck has one but if so, have you checked the starter relay? I don't mean the solenoid- there could be a separate relay in a panel in the engine bay.
Old Mar 4, 2011 | 03:07 PM
92nite351's Avatar
92nite351
wel as it turned out, the problem was a ground that i never knew these trucks had. so thanks everyone for the help. it needs new terminals and had to fix a couple grounds and she started right up.... thanks everyone
Dmansnyd
Dec 10, 2013 01:01 PM
blt93932
Aug 23, 2011 10:00 AM
facotaco
Mar 6, 2011 12:55 AM
godawgz99
16
May 25, 2008 07:02 PM
