Just noticed brake fluid leaking down sidewall of tire on to driveway. This E-450 sits alot. Do I need to rebuild/replace this caliper or after driving again will it seal back up?
Mine is also leaking. It appears it's leaking/seeping from the lower bolt on the caliper; facing the inside of the truck. There appears to be a black rubber accordion style boot between the bolt head and caliper and that's where it looks to be coming from. There are no leaks from any lines or anywhere else, only there. Is this a simple fix or do I need an entire new caliper? Any advice is appreciated!!!!!
Bust seals or washers or trucks rarely fix themselves. You can try the give it a wack thing, but I'm guessing whatever is leaking will need to be replaced.
If it jams, force it. If it breaks, it needed replacing anyway.
