Sponsored by: Real Truck
Transmission problems
Old Mar 3, 2011 | 02:45 PM
TexasRebel's Avatar
TexasRebel
Unhappy Transmission problems
So I'm sure you automatic guys will do a jig at this report...
This might be the worst problem ever reported with a ZF6... my transmission has developed a loud rattle during operation. It doesn't seem to affect the shifting at all, and it still seems to operate well, but sometimes it seems that R is all the way in and up... while a few miles down the road it will be all the way up and right... then before long it will be all the way left and down... ...well you get the picture.
Does anyone know how to keep the shift pattern button from spinning and rattling?
Old Mar 3, 2011 | 06:47 PM
TexasRebel's Avatar
TexasRebel
but seriously... I'm sick of this rattle.
How do you tighten the little plastic circle on the shifter?
Old Mar 3, 2011 | 08:19 PM
sandrat's Avatar
sandrat
Glue? Pretty sure it's just glued in.
Old Mar 3, 2011 | 08:32 PM
TexasRebel's Avatar
TexasRebel
I can't figure out a good way to pry it out...
of course all I've attempted is using my fingernail... I wanted advice before putting a screwdriver to it.
Hopefully once I get it apart I can find something better than glue... I'm thinking the torque my hand applies to it mixed with the heat of the summer is what made it loose in the first place...
Old Mar 4, 2011 | 06:56 AM
bucci's Avatar
bucci
My guess is that the disc part has a small tongue all the way around it that fits into a corresponding groove in the **** and all it does is snap in. I don't think there is any glue.
I could turn mine with a little force to any orientation I want, probably could do the same with the t-case **** too.
Back when the manual trans was a factory option , I've seen many brand new trucks on the lot with the shift pattern disc in all different orientations.
When I got my truck, the first thing I did when I got in to drive it home was turn the shift pattern disc to be perfectly parallel with the seat when the stick was in the neutral position.
Old Mar 4, 2011 | 08:23 AM
89LX306's Avatar
89LX306
I knew those ZF6s were junk.
Apparently Ford can't get those shift ***** right. I drove a 95 F150 with a manual and the shift **** did the same thing. You are right...it is annoying.
Old Mar 4, 2011 | 09:04 AM
timster24's Avatar
timster24
Had the same problem with my 1984 Ranger, so I glued the thing in place, problem fixed
Old Mar 4, 2011 | 09:08 AM
Snowseeker's Avatar
Snowseeker
I always played with the disc while driving. Never bothered me really. Just squeeze some super glue in there.
eatont9999
Aug 14, 2011 09:57 AM
rbegga
May 2, 2008 11:31 PM
mjbesen310
2004 - 2008 F150
Nov 22, 2004 05:18 AM
BlueOvalFitter
1997 - 2003 F150
Apr 11, 2004 09:58 AM
rebsbg
1997 - 2003 F150
Mar 16, 2002 09:39 PM
