93 E150 Doesn't Crank
Old Mar 3, 2011 | 01:33 PM
rbrent111's Avatar
rbrent111
I have a 93 E150 I need some help with. The van stopped in a parking lot and didn't start. It's ran flawlessly for years. Now when you turn the key, nothing, no lights on the dash no power to the windows, headlights come on, Key alarm sounds, Interior lights work, nothing else.
I can crank the motor by jumping the solenoid. Engine does not start with the switch in the on position. Replaced the ignition switch on the column where the harness plugs into and it did not fix the problem. Nothing different if in N or P position. There are no aftermarket alarms to interfere.
What is the most likely problem or what series of tests can I do to diagnose the problem?
Old Mar 3, 2011 | 05:27 PM
subford's Avatar
subford
Sounds like Fuse "G" a 60 amp fuse in the engine compartment fuse panel is open (bad).
1993 & 1994 should have the same fuse layout:
Old Mar 4, 2011 | 12:23 PM
rbrent111's Avatar
rbrent111
Subford,
Thanks for your answer. You are correct. I popped the fuse out, it was blown, new one in and it's back to normal. Now just to figure out why it blew. Any thoughts?
Thanks for your help!
Bodacious-08
Sep 13, 2014 04:10 PM
infinite-foamies
Nov 20, 2013 07:27 PM
Mach73
Jul 11, 2004 05:08 PM
CHADRINTX
Sep 3, 2003 12:55 PM
lghtningstruk
Jul 13, 2002 07:48 PM
