Disconnected battery - alarm problems
Old Jul 13, 2002 | 01:52 PM
lghtningstruk's Avatar
lghtningstruk
Help,
I disconnected the battery to clean the battery tray, and when I hooked it back up the alarm system is acting up. The door locks will lock and unlock from the key fobs, but the alarm doesn't sound anymore. Also when I enter the vehicle with the key (alarm supposedly set) the alarm will not sound. However when I do set the alarm, reenter the vehicle by using the unlock on the key fob - the engine will not crank - I have to use the bypass button to start the engine. By the way it is a 1994 F150 with the factory Ford alarm/keyless entry system. I don't have any manuals on this alarm system because I bought the truck used.
Any help would be appreciated.
Carl
Old Jul 13, 2002 | 04:27 PM
lghtningstruk
Just wanted to let you all know that I disconnected the battery again, and hooked it back up and everything is working fine now.
Thanks
Old Jul 13, 2002 | 07:35 PM
ftrain's Avatar
ftrain
Glad to hear it..
Seen lots of things with alarm systems and audio (not to mention ECM's) after battery disconnects...if all else fails, reboot!!
Ronnie
1987 F150 Reg Cab, 302MFI, AOD, 3.55 Rear, K&N Filter
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4972&.jpg
Old Jul 13, 2002 | 07:48 PM
GSchretter's Avatar
GSchretter
towme
Jun 15, 2021 09:30 PM
Paul98038
1997 - 2003 F150
Dec 31, 2019 03:57 PM
baylor3217
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 7, 2013 07:31 PM
CHADRINTX
Sep 3, 2003 12:55 PM
