Just curious how most approach when to change the air filter. I just did it every 30,000 miles or so before I read on here that there is a dash icon indicating when it is time to change it. My filter minder does not change much, the smaller yellow ring is now at about 65% and I have 41,000 miles on it. So just curious what those in the know do here, thanks for any input. I am thinking this time I will wait until the dash light comes on: this is what happens when you retire...you become way more patient.
By the way, I struggled and fought changing that thing before watching the video that is widely available and reading up on it in the tech folder...there is an easier way!
I just watch the indicator on the filter. It's an industrial filter that can hold a lot of dirt, several pounds IIRC. Each time I have had to remove the filter I tap it and knock out the dust/grit.
I bought my truck used with 40K miles on it. I changed the AF when the filter minder showed about 25%, which was about 100K miles. I now have 130K miles and the filter minder is about half way to 25%, or appx. 10%. For the next AF change, I would feel comfortable up to 50%. At the rate that I am going, that should be sometime in 2019.
the filter minder is used on prettymuch all medium and heavyduty diesel applications.. it is there to stop you from taking the filter out and banging it to remove the dirt thereby perhaps causing damage to the element as well as letting dirt into your intake system.
If you know more than the engineers that designed the systems then go ahead and waste your money on filters!!!!!!!!!!!!1
I am guessing that your comments are aimed my way since you to refered to banging the dust out of filters.
The filter minder is there to measure the pressure drop between the filter and the turbo. As the filter becomes plugged the colored piston is moved by the lower intake pressure. That is why one poster suggested resetting the filter minder occassionally to make sure it is working.
Knocking some of the heavier dust out of the element will extend the filter useful life. If you re-read the original post you will find that I said that I knock the dust out when I have the filter off for other repairs. That would be for a cooler replacement, a turbo cleaning and a water pump replacement. The filter has a heavy case and would not be damaged by gentle taps on the ground, I do not use a 2x4 or a hammer!
By the way I have worked for over ten years for a large diesel manufacturer and several years for a large diesel distributor. How is cleaning dirt out of a filter while you have it off the engine wasting money on filters???????????????
I changed mine at 80,000 miles. The filter minder said it was ok and it looked really good when I pulled it out. It had been in there 5 years and 80,000 miles so I figured it deserved a new air filter so I put it in!
3lbs of dirt to be exact.
i have 60k on mine its still going good. I live in town and pretty much stick to the city. I may change it soon anyway
If you have ever taken the time to read some of the literature provided by companies such as Donaldson, Baldwin, etc. you would see that in most diesel applications they suggest using the filterminder to monitor filter condition and not to remove the element and look at it to determine if it is good or not. They specifically mention not to bang the element to remove dust as you risk damaging the element. Additionally the coating of dirt on the outside increases the effectiveness of filtration {their words not mine}
I've worked in the truck and heavy equipment business for a long time and have seen a lot of wasted money on air and fuel filters
If you have ever taken the time to read some of the literature provided by companies such as Donaldson, Baldwin, etc. you would see that in most diesel applications they suggest using the filterminder to monitor filter condition and not to remove the element and look at it to determine if it is good or not. (1.) They specifically mention not to bang the element to remove dust as you risk damaging the element. Additionally the coating of dirt on the outside increases the effectiveness of filtration {their words not mine} (2.)
1. If you would read the posts you would know that I use the filter minder to monitor the filter condition.
2. If you would read the posts you would know that the only time this happens is when the filter has been removed for other repairs and the dust has already been disturbed.
One question about the filter minder.... does the truck need to be running to read it? Mine is always at the far end of it when I check (farthest away from needing to be changed). I've got 50k on the truck and I don't believe the filter has ever been changed (bought the truck with 36k on it).
