clutch options
Old Mar 2, 2011 | 08:42 AM
ff1210's Avatar
ff1210
clutch options
Whats most people using in there trucks? I do a lot of pulling 14,000 and down five days a week and got a lot of up grades comming to the motor about 400 rwhp will be the max. Just wanting a good replacement clutch got 130,000 out of the stocker. Thanks for your help.
Old Mar 2, 2011 | 09:49 PM
ff1210's Avatar
ff1210
EVERY BODY ON HERE MUST HAVE AUTOS IN THERE TRUCK.
Old Mar 3, 2011 | 01:42 PM
Lazy K's Avatar
Lazy K
You are probably right, most guys here do seem to have autos (including me).
However the stock clutch should be LUK so if you want to go again check out those. Carolina Clutch was doing good deals on them a while back.
Old Mar 3, 2011 | 05:28 PM
Beechkid's Avatar
Beechkid
these guys have been building my clutches for 30+ years.......for all applications, typically a 24 hour turn-a-round. They have always worked right the 1st time and last 100k+. Prices are typically less than OEM, and the other "performance guys".
Clutchmasters
267 E. Valley Blvd. Rialto, CA
909-877-6800
Old Mar 3, 2011 | 07:55 PM
ff1210's Avatar
ff1210
Clutchmasters
909-877-6800
my dad always said a rebuilt clutch would be better than the one that came in it.
Old Mar 4, 2011 | 03:34 PM
xlt4wd90's Avatar
xlt4wd90
Can someone educate me here; what do you do when you rebuild a clutch?
I've replaced clutches before, and the structure was a center hub coupled through springs to a larger disc lined with friction materials on both sides. I once also replaced the pressure plate, which a structure that had 3 levers that lifted a spring loaded plate off the clutch friction plate.
Does "rebuilding" a clutch mean replacement of some of these component parts? Or is the clutch for a big truck much different than for a pass-car that there are more parts to it?
Old Mar 5, 2011 | 12:00 PM
Beechkid's Avatar
Beechkid
The disc is new & the throw out bearing is new, the pressure plate is disassembled, new springs, levers, etc, the disc mating surface is resurfaced or replaced and the metal shell is magnafluxed to check for weak sopts and replaced if necessary- basically it's all new.
Old Mar 14, 2011 | 02:52 PM
ff1210's Avatar
ff1210
clutch
come on any one else got a good clutch option.....
Old Mar 14, 2011 | 03:51 PM
Lazy K's Avatar
Lazy K
A lot of guys will say that Centerforce is as good as it gets.
Old Mar 15, 2011 | 10:31 PM
lovemy7.3!'s Avatar
lovemy7.3!
try Valaire . i just replaced mine and the $ i saved allowed me to upgrade to a 350HP clutch. alot of the guys here use these clutch kits. mine went in with no issues and performs perfectly. ive got about 15 miles on it. im supposed to take it easy on it for the 1st 500 mikes or so. i also got rid of that dual mess flywheel and put in a solid one. guess what...no more rattleing noise! im driving a F250PSD 4X4 by the way. and i also changed out the rear main seal while i was in there. my old 1 was just barely leaking so it was time.
Old Mar 16, 2011 | 05:25 PM
Beechkid's Avatar
Beechkid
I'm not quite sure what you want...
OEM is good but pricey
Centerforce is an excellent product but more than oem (typically)
Clutchmasters is an excellent business for having them either rebuild your clutch or provide one outright to you, price is less than OEM or Centerforce...an equally well known name for 30+ years in SoCal, building oem replacement units to providing products for NASCAR, INDY, etc.
There would be clutch rebuilders in your area as well....most are very good at what they do and have access to the same materials (parts) as anyone else! It's just a matter of assembling the correct parts for your application and operational needs.
Dan Robertson
1983 - 2012 Ranger & B-Series
Jul 12, 2013 09:38 AM
Bird Hunter
Apr 23, 2013 07:52 PM
Jmatthews
Apr 15, 2010 06:32 PM
Tool_41
Apr 13, 2003 02:24 PM
