Adding cruise control
not hard to add the oem system. You need the steering wheel cover with the buttons and then look under the hood of a truck with cruise... there will be 2 cables hooked to the throttle cable plate by the carb. one is the throttle cable and the other will be a vaccum controled cruise control system. Take everything behind the cruise control cable back to the wiring and vaccum lines... then reverse your tear out onto a install on your truck!
dylansf23
19
12-17-2014 11:14 AM
