A few questions about my '01 F-150
To start, I'd like to say that I'm really new at trying to work on my truck myself. Mostly I'd like to figure out what is wrong with it before I take it in and get taken for a ride by some mechanic that sees a female and thinks I'll spend crazy amounts of money on repairs I don't need. Did that last year and am quite sick of it.
I've looked around in the FAQ's and have found a couple answers already, and since many here seem to be very knowledgeable about these things, figured I'd ask.
A couple issues I didn't see the answers to:
First, when I turn the wheel to the right almost as far as it will go there is a loud thud. It almost sounds like something is going to fall off and has made me think I've hit something a couple times, it's that loud, and the whole truck shudders.
Next, this is a new thing, usually happening when I've just started the truck and am backing out of a parking spot, or just getting ready to drive off. The RPM's will start to go up and down and the whole truck rocks back and forth. It's done this about 6 times now and just started about a month ago.
Last (for now), the engine oil light occasionally comes on and the dial drops all the way down to L. I checked the oil today and just got it changed recently by my Ford dealership, so I know the oil level isn't low. Sometimes when this happens the temperature gauge also drops all the way down to C, but not always. The oil gauge has done this ever since I bought the truck three years ago.
The truck itself is a 2001 4x4 4.6L
Welcome to the site!
How many miles do you have on it?
1) Is your truck 2wd or a 4X4?
2) Have you had the codes read? It could be the IAC or a vacuum issue.
3) I would have the oil pressure checked.
It's great to have you here and there are a lot folks who can help you out and keep your truck running.
I have 111,000+ miles, it's a 4X4, I can get the codes read at Autozone or the like, right? I know they'll do a free read, but the repair shops assure me that that one only gives a general code and the way to find the real problem is to spend $45 and get it done there. As for the oil pressure, I'll go in to the Ford Dealership and see if they'll check it for me, unless you guys have a better suggestion for a place to get that done.
Thanks for welcome and the help so far!
Goodluck on the truck! hopefully all gos well!
Welcome to the site.
Get the codes read for free if you can. Wright them down and post them here. We wont charge you 45 bucks to help you figure out what the problem is...lol
The codes are online but every code you get doesn't necessarily mean that's the problem.
In other words, you could have multiple codes that would lead to a certain other problem .
Ford DTC Codes
Ford DTC Codes
Just wanted to update you guys on my truck.
Figured out what was making the loud noise when I turned the wheel to the right. Last November I got the idler arm replaced at a Firestone. Turns out the install wasn't done properly and the arm was loose! I got lucky and nothing else was damaged since I'd been driving around with it like that for months. I didn't find it sooner myself because, even though I had gotten under the truck and checked the idler arm myself, I hadn't been able to shake it. A friend from work found it for me though, and I took it back to Firestone and got it taken care of for free.
Still have the other issues though. Figured out that I have a faulty instrument panel, but I'll just deal with that for now, since it's not anything life threatening.
Thanks again for your suggestions. I'll have The Beast like new before too long!
Don't feel bad, I've been fixing my trucks for years and I still "need more tools". ha ha !
Start with standard tools like 3/8" socket set, screw drivers, wrenches, pliers, etc. Specialty tools can be expensive and you can rent them for a day or two at most auto parts stores.
Hang in there, you're doing great.
i love this! i usually go to my in laws and steal his warm shop for my truck to work on as well. only down side to being a truck owner and an average sized female is i need a step ladder to get in it! great to see other women who arent afraid to get down and dirty to save money on repair bills
Trailblazed
26
03-25-2018 09:28 AM
Trackerrrr
17
10-30-2014 03:19 PM
Fordownsall
22
11-30-2012 10:03 AM
nothercrash
29
09-14-2010 11:18 AM
