Minnesota Chapter Join Chapter, Leader: fordpower88
March BS Thread
Old Mar 21, 2011 | 02:56 PM
  #1171
Ford79's Avatar
Ford79
Originally Posted by fordpower88
Good morning Mike! How is your Monday going so far?
Pretty good so far.
Originally Posted by DieselCamper01
Good morning Lee and Mike.
We never laugh at other's misfortunes...
Good morning Jay.
Well hopefully the leak is an easy one to fix. Cosmetic can be fixed relatively easy. The main thing is mechanically it is good!
Sounds like we need a gtg in the future to get some work done on these trucks. Maybe a two day event or something. I would like to have one out here I am thinking end of April or early May. I will know more on timing once I get all my goodys ordered up for the truck.
I have a list to do at a GTG too, though it is a little more ambitious than checking for coolant leaks and bolting a few parts on............
Originally Posted by dlibson
Oh, and pictures really help this truck. It's rough, but so was the dually when I got it..
Edit: speaking of which I need a box if anyone sees a good clean short box.
I'll keep an eye open for one, they seem to be a lot harder to come by than the long boxes that's for sure.
Technically yes Chris but it makes more sense to replace the whole box on a MN truck if you can.
Yeah, much easier to remove 6 or 8 bolts than mess with cutting spot welds and lining the new panels up and re welding everything.
Old Mar 21, 2011 | 03:10 PM
  #1172
Jbotto's Avatar
Jbotto
Hey guys! If one of these GTG's are late enough into May, I'll most likely be there! I have a strange lean in my truck lately... Someone told me my springs might be going bad... if I could risk the drive back home again, I'd probably wait til then, unless it's something that could prove detrimental to the health and wellness of my truck.... I could probably do my shocks at the same time.
Old Mar 21, 2011 | 03:16 PM
  #1173
dlibson's Avatar
dlibson
Box sides are $525 a side oe, and still need paint. Find a box for 500 and go!
Old Mar 21, 2011 | 03:22 PM
  #1174
MisterCMK's Avatar
MisterCMK
Along with what Jay said the labor invovled to replace both box sides is fairly invovled. If you can find a good box and just paint it you will actually be money and time ahead.
Ouch, those are spendy! I didn't even think about the MN truck part.
Do you have any connections through work Dave? Also, long bed or short bed?
Old Mar 21, 2011 | 03:23 PM
  #1175
MisterCMK's Avatar
MisterCMK
Hey, you could do an 08+ tailgate and rear bumper with the tails to go with it!
Old Mar 21, 2011 | 03:28 PM
  #1176
dlibson's Avatar
dlibson
I've considered that chris! I do have some connections, so I'm working on those. It is a short box.
Old Mar 21, 2011 | 03:46 PM
  #1177
fordpower88's Avatar
fordpower88
Pretty good so far.
Yeah Mike you for sure have a project there! I am hoping my up pipes arent as rusty as yours and as far as I can tell they are not. If we end up doing yours here you may have to pull your camper with and spend the week here!
Hey Jake! I am thinking my gtg will be in early May but I am sure we can have another one later on! With your truck sagging I would start taking measurements from side to side and see what part is sagging. Make sure something isn't broke.
That would be cool!
Old Mar 21, 2011 | 04:02 PM
  #1178
DieselCamper01's Avatar
DieselCamper01
What is the best way to check for bad wheel bearings? What do I look or listen for?
Old Mar 21, 2011 | 04:11 PM
  #1179
fordpower88
Well if they are bad enough you should be able to hear them. If you are driving down the road and swerve left and right or going around curves the sound should change. If it does that is a pretty good sign of a bad wheel bearing. I am not sure how to desribe the sound exactly......
Old Mar 21, 2011 | 04:22 PM
  #1180
mndiesel's Avatar
mndiesel
Morning Scott, Steve, Troy, Chris, Dale, and everyone else!
Yeah Tom, it's something else, huh?
It just looks really BRIGHT, could be the pic though.
Hello to the rest of you......
  #1181
DieselCamper01
I am hoping it is just my rotor since it seems bad only when braking but it is hard to hear over the engine noise...
  #1182
DieselCamper01
Hey there stranger. How are ya?
Old Mar 21, 2011 | 04:24 PM
  #1183
MisterCMK's Avatar
MisterCMK
Howdy Tom.
It looks like the proper mounts for my lights came in. No more "home-brew" mount. lol
Old Mar 21, 2011 | 04:25 PM
  #1184
mndiesel's Avatar
mndiesel
Jay I can't believe you had problems with the Cryo rotors, I take it they are out of wty. I have had mine 3 1/2 years and even had one get up to 300 degrees with a seized caliper and they are still solid. I got mine from a place in Burnsville........Maybe it wasn't fully Cryo'd......Just a thought...
Old Mar 21, 2011 | 04:27 PM
  #1185
fordpower88
Hey Tom!! How are ya doing?
If your bearings were bad you should be able to hear them when you are cruising at highway speed. Pretty distinct sound. Maybe the problem is all the extra sounds you get down there in the city! You should come out here to the piece and quiet and then it will be real easy to hear everything! LOL You can have supper while your out here as well!
