Good morning Lee! I see your posting at the same time as me again! LOL Yeah that size of tractor will either move it or break it but one way or another it is gonna get the job done!
Yeah Jay, it might be worth it. Truck seems pretty solid mechanically, an oil leak from up above somewhere. Maybe turbo pedestal? Some sway bar bushings too. Just needs to be cleaned good and have the body fixed up
I can't wait to see the truck Dave. It sure looks nice overall.
I have some issues with mine I need to check out. Not sure if it is my brake rotor getting goofy or if I have bearings going out. And I am loosing antifreeze somewhere. I am down about a gallon and not a single drip...
Well hopefully the leak is an easy one to fix. Cosmetic can be fixed relatively easy. The main thing is mechanically it is good!
Sounds like we need a gtg in the future to get some work done on these trucks. Maybe a two day event or something. I would like to have one out here I am thinking end of April or early May. I will know more on timing once I get all my goodys ordered up for the truck.
That's the big thing Troy. As long as the truck works good, I can make it look better. A gtg might be good once I figure out what I'm gonna be doing with it.
Yeah by the time I am ready for a gtg out here you should have a handle on what you all need done.
Originally Posted by MisterCMK
You can't just replace the box sides?
Technically yes Chris but it makes more sense to replace the whole box on a MN truck if you can.
Along with what Jay said the labor invovled to replace both box sides is fairly invovled. If you can find a good box and just paint it you will actually be money and time ahead.
