1999 e-150 conversion towing
Old Feb 28, 2011 | 12:16 PM
stang99gtv8's Avatar
stang99gtv8
I am looking at getting something to tow my trailer with and peaking my interest lately has been the e-150 conversion van for multi-purpose use. My trailer is a 1400lb. 6X12 enclosed trailer loaded with about 500lbs. of equipment, getting it around 1900-2000lbs. total that would be pulled. I'd be putting a class 3 hitch on the van. Could it do that and at least 4 people inside?
The one I am currently looking at is a 4.6L version.
Old Feb 28, 2011 | 01:29 PM
418's Avatar
418
I pull a 5X10 with 600+ pounds on it with three people inside and loaded with at least couple hundred pounds of gear. You'll be fine, I tow mostly out of OD and run around 75mph. Do 70mph up any hills easy. It's not happy per say but it's not screaming either. You could slow down for upper 60's and it would be completely content.
Mine is a E150 4.6 '99 Conv as well.
Old Feb 28, 2011 | 01:31 PM
stang99gtv8
Exactly what i needed to know, thank ya!
Old Mar 2, 2011 | 02:41 PM
redtanrt10's Avatar
redtanrt10
Here's a good reference guide from Ford. It only goes back to '99 but it should help you. Mike
https://www.fleet.ford.com/showroom/...02_default.asp
pin8246
May 19, 2018 01:47 PM
flyboyaviator
Aug 30, 2015 03:10 PM
Jim1995E150
19
Dec 10, 2004 06:58 PM
Bruinzfan
All Things Towing
Dec 13, 2002 10:36 PM
chemgoddess1
Oct 21, 2001 03:55 PM
