need help gents
Old Feb 27, 2011 | 06:41 PM
brycemc's Avatar
brycemc
need help gents
so i'm changing the glow plugs in the 94 7.3 turbo got 7 in no problem. the one directly under the turbo 2nd one from the back broke off in the head. the threaded portion came out the rest is stuck in the head. so i start pulling the turbo off. crossover pipe is out down pipe is disconnected. my question is how the hell do you guys get the 4 bolts off the hot side of the turbo. 2 of em came off the other 2 are still there and i can hardly get a wrench on em let alone enough force to break em loose.
Old Mar 1, 2011 | 10:55 AM
Gen 1 driver's Avatar
Gen 1 driver
where are all the wrench wizards out there. Has to be a secret to getting to those 2 bolts?
Old Mar 1, 2011 | 11:10 AM
snaponprofile's Avatar
snaponprofile
I've never done it on a factory turbo but my banks was pretty tough, I had to use multiple extensions and swivels to get to 3 of the 4 in and out.
Old Mar 1, 2011 | 02:01 PM
tjc transport's Avatar
tjc transport
i ain't rite
when i do the banks units, i leave the turbo mounted to the pedistal, and remove the 2 bolts from the back of the head. turbo and pedistal come off with no problem.
Old Mar 1, 2011 | 04:19 PM
snaponprofile
You must do the older version cause mine doesn't sit on a pedestal.
Old Mar 1, 2011 | 04:52 PM
gumboluvr's Avatar
gumboluvr
Brycemc, there is a supplement for the IDI turbo, that you must have. It makes turbo removal a walk in the park. I forget where I down loaded it. I have it in PDF . Send me a private message, and i'll send it to ya.
atomburst
Dec 28, 2010 08:56 PM
Festus Hagen
21
Apr 5, 2010 07:43 PM
BobDG
Aug 14, 2009 08:59 PM
ubereal2
Missouri Chapter
Feb 19, 2008 11:30 AM
sterlingstein
New Member Introductions
Jan 9, 2008 09:25 PM
