auto code scanner
Old Feb 27, 2011 | 06:58 AM
fishslayer14's Avatar
fishslayer14
auto code scanner
hi there iam new here ,im looking for a code scanner,for my 1994 explorer v6 4x4,can anybody help me with the right 1 for this suv, make and modle of the scanner would be helpful thank you ...........
Old Feb 27, 2011 | 07:57 AM
shorod's Avatar
shorod
Let's start by finding out what capabilities you are looking for from the tool. A "code reader" will just provide you with the diagnostic code. It will not provide you the ability to perform datastream monitoring of sensor values real time and may not even provide the ability to easily clear codes. You do not need a tool any more expensive than a paperclip to do this function yourself on your 1994.
A "scan tool" will provide you the ability to read and clear codes, access freeze frame data (which may not be implemented in your '94), and monitor some datastream parameters.
Also do you want something that will work on 1996 and newer vehicles (assuming you're in the US) as well? Do you need something that is able to access diagnostic codes for the transmission, ABS, and/or airbag systems? Do you have a target cost in mind?
-Rod
Old Feb 27, 2011 | 12:24 PM
fishslayer14
cost is no problem iam in jersey,which 1 would you recammend then and thanks for your reply......
Old Feb 27, 2011 | 12:28 PM
fishslayer14
yes a scan tool sounds like it .as i would need to read whats happening to my trans if any problems occur.....
Old Feb 27, 2011 | 01:25 PM
aquanaut20's Avatar
aquanaut20
Google is your friend when you are researching/looking for information.
AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
ScanTool.net LLC - Scan Tools, PC, iPhone, & Android based OBD-II (OBD2) Interfaces, OBD diagnostic software
AutoTap Express DIY - OBDII Scanner
There are less expensive options but that requires your time to search.... Philip
Old Feb 27, 2011 | 01:34 PM
rolleye's Avatar
rolleye
I think he needs an OBD - not OBDII for his '94.
Old Feb 27, 2011 | 01:45 PM
aquanaut20's Avatar
aquanaut20
I was aware of that but he asked for a scanner that would look after transmission live date/codes (his answer to Shorod), which are not available unless access to professional equipment.
That was why I suggested he use a search engine and investigate.. Philip
Old Feb 27, 2011 | 05:12 PM
shorod's Avatar
shorod
I would suggest you look at a used OTC Genisys (or one of the rebadged versions) or an Autel MaxiDAS DS708. These tools will work with OBD and OBD-2 as well as be able to access all the systems with the correct software.
The OTC is more pricey to update than the Autel, but the OTC has better customer support.
-Rod
Old Feb 27, 2011 | 05:45 PM
aquanaut20's Avatar
aquanaut20
I have one of these http://www.tooltopia.com/equus-3120.aspx in my tool box, good for OBD, OBDII and CAN systems, but does not have live data... There is an upgrade model http://www.tooltopia.com/equus-3140.aspx that outputs live data for OBDII.
I have several of the Computer based scanners (LIVE data), that cover OBDII and CAN, but not OBD....Philip
Old Feb 27, 2011 | 05:55 PM
fishslayer14
THANK YOU PHILIP FOR YOUR HELP TODAY I SEE WHERE IM HEADING NOW ,SAW SOME ON EBAY FOR ABOUT 130, OR SO..if you want to sell me 1 of yours that will do the job for me ,we can talk price .........thank you once again.
Old Feb 27, 2011 | 07:52 PM
aquanaut20's Avatar
aquanaut20
LOL! I was once told, "the man with the most toys when he dies, WINS!"
I have worked hard at this and not about to squander my standing..... Philip
Old Feb 28, 2011 | 04:16 PM
fishslayer14
yes indeed my friend...yes indeed..
mathew john
Nov 5, 2018 10:54 AM
wracefans24
2004 - 2008 F150
Jun 23, 2015 01:47 AM
wracefans24
2004 - 2008 F150
Jun 15, 2015 01:37 PM
jayc3169
Mar 15, 2011 09:09 PM
