need help f250 4r100 problem code p0715
5 months ago i brought a f250 7.3 2000 model the car i always wanted and to take a trip around australia but im having problems with the 4r100 transmission that was rebuilt before i purchased the truck
THE PROBLEM and checks
Truck taking of in 3rd can manual select 2nd but not 1st
Getting Codes P0715 , P0717 changed turbine speed sensor checked wiring to pcm all ok codes still comming up
put truck on scanner and found TSS reading when manualy in 2nd but not in park neutral or drive
removed PTO cover to check gear turning that the TSS reads from with the truck up on stands the gear only turns in 2nd when in park neutral or drive it is stopped verifing what the scanner is seeing
the scanner also see the gear changes but the transmisson is not changing
could anyone please help or give me some insight
thanks in advance from down under
rickjamess
07-09-2019 11:25 PM
White Light
05-16-2019 07:11 AM
Pat.Bomb
06-20-2011 03:45 AM
