ABS LIGHT KILLING ME
Old Feb 28, 2011 | 05:04 PM
excursiondude's Avatar
excursiondude
Originally Posted by EXv10
Good luck with it, we are just trying to help and maybe one of us will hit on something. It just seemed strange that someone said to change the diff oil when the fronts are subjected to grimy grease, water, etc, and still work. Actually the diff vss would still work if it had 400,000 miles on the oil and been through 500 puddles. About the only thing that could stop it is removing the tone ring. Consider the vss contol module also.
HowStuffWorks "How Anti-Lock Brakes Work"
Thanks for all the help. I have changed the vss no change. Your right the rear lube was a waste. I hope the Ford guy finds something, I go to him tomorrow. Love this forum lots of good guys and girls to bounce ideas off of.
Peace
Dave
Old Feb 28, 2011 | 06:23 PM
jasonodsky's Avatar
jasonodsky
After replacing the sensor, you may need to disconnect the battery for 30+ minutes for the 'puter to reset and recognize the new sensor. I know my 'puter knows when I've just disconnected and reconnected the sensor with the ignition off. ABS light stays on for 30 seconds till it figures out all is still OK. Maybe try the disconnect again and see if you get the first 10 miles problem free again?
I think the reason for changing the diff oil is to remove any metal shavings which could be disrupting the sensor from picking up the tone ring properly.
When you drain the diff, you also need to clean out the bottom of the pumpkin or you won't get all the metal shavings. Rubbing a magnet around the bottom can be an extra help too. If you didn't clean the metal out carefully, it got flung around again. Maybe check the sensor, post old change to see if metal shavings are on it again. That could tell you something.
The diff cleaning has helped out more than a few on the forum to solve the problem. Then again...it could be something else still.
I have also heard others report misfires not registering codes early on but there can still be a coil pack going bad.
Please report back the solution. I am curious.
Last edited by jasonodsky; Feb 28, 2011 at 06:37 PM. Reason: revise comments in first paragraph to clarify battery disconnect reasons
Old Mar 1, 2011 | 11:24 AM
EXv10's Avatar
EXv10
I doubt very much if anyone has corrected the problem by simply changing the diff oil. Even a lot of metal in the oil is not enough to fool the sensor, I'm sure they made other changes also.
Old Mar 2, 2011 | 06:42 AM
tdappleman's Avatar
tdappleman
Do you have a lift installed or have you had any front end work done? I've seen the front ABS cables get stretched which can cause intermittent problems - usually ending in an actual failure. I'm surprised you're getting a constant light with no actual code being set.
I'd check and clean your front wheel speed sensor connections in addition to what has already been suggested.
Old Mar 12, 2011 | 06:31 PM
excursiondude
UPDATE
Originally Posted by Shepherd2
Since you think it's funny I'll keep my 18 years experience as a Ford tech to myself. Checking for an engine misfire to fix an abs problem, now thats funny.
You know what? keep it to yourself. Cause you have no idea what The fix is. Sorry but that goes for EXV10 guy also. You both made me feel like ***** cause I asked a question. You were WRONG!. I have the problem looked at by a 30 Ford tech and he said to change 2 coils. I also replaced the plugs. one of which was .98 gap. I have put on over 700 miles with no speedo drop or abs light. Thanks jasonodsky,tdappleman,and CrzHelm I come to this forum to find help and you guys are the ones who offer assistane. I am 47 years old and I am a 1 year ford tech that now knows how to trouble shoot problems. Thank you for your help.
Old Mar 12, 2011 | 07:37 PM
EXv10's Avatar
EXv10
I never blamed you for asking a question or said it wasn't a certain thing, I just said it wasn't the differential oil. I don't expect everyone to be a mechanic and you probably accel in another field where I would be lame. I know first hand that vehicle problems can be overwhelming and we are all just here to help.
Old Mar 12, 2011 | 08:12 PM
EXv10's Avatar
EXv10
No, don't keep it to yourself! We need people like you in here. Anyone that does something 8 hours a day is going to have 100 times the experience of the layman. It's like a plumber telling an electrician how to wire a breaker panel. (being serious here).
Old Mar 13, 2011 | 07:48 AM
tdappleman's Avatar
tdappleman
Glad you got it resolved. Do you know if they did any specific troubleshooting to get to those 2 coils?
Old Mar 13, 2011 | 07:57 AM
katiesdad7's Avatar
katiesdad7
FWIW, when I installed my HID's I got the same problem you have. I moved the ballast for the drivers side over about 6 inches and that took care of the problem. Don't know if that will help.
Old Mar 13, 2011 | 08:02 AM
jasonodsky's Avatar
jasonodsky
Glad you got it resolved. It seems our X's have very specific problems/resolutions and if you troll this forum frequently enough, you'll see the trends of what is usually the simplest most effective fix. Enjoy driving your trouble free X!
Old Mar 13, 2011 | 08:50 AM
excursiondude
Thanks everyone. I love this big old truck and I plan on keeping it going for a long time. By the way tdappleman. He just hooked it up to ford scanner and said I had a few hundred misfires. I checked the resistance of the questionable coils and the 2 were different than the other 8 not by much. I had 4 brand new coils so I put them all on the passenger side from rear up. As you know that side is a PITA to get to. LOL Runs like a scared rabbit.
Dave
P.S. hope I never have to change those plugs again. Took me a few hours a day over 3 days. I let them sit in Kroil overnight.
Old Mar 13, 2011 | 01:38 PM
EXv10's Avatar
EXv10
On that right rear side; I took 2 brackets off (just a few easy bolts), they were to the throttle and an ac control, I also twisted off the tube going to the injector intake, pushed the remaing hoses etc out of the way, un-did all the injector and cop wires back there and tucked them out of the way, removed the cops and boots, put the carefully chosen extension in the rear hole, and in a few minutes the plugs were out. The 10 minutes of prep here saved a ton of frustration.
Old Mar 13, 2011 | 09:55 PM
  #28
Jaykane's Avatar
Jaykane
Urban Assault Vehicle!
Just in case some people are wondering, here is a video of mine doing the same exact thing. I changed my VSS and problem solved. But if this video helps anyone understand any better than I'm glad to help.
vze2sgxa
Feb 22, 2014 09:59 PM
zrt600guy
1983 - 2012 Ranger & B-Series
Feb 14, 2012 04:10 PM
jgilrfr
Jan 30, 2012 06:06 PM
davrober
Jun 1, 2007 03:58 PM
scottson
Electrical Systems/Wiring
Sep 18, 2003 09:06 AM
