F code rear springs
'04 Eddie Bauer Ex, 6.0 PS. The truck has the towing package so it has the steering damper/stabilizer and rear anti-sway bar. We will be using the truck to tow our 34' TT which weighs in at about 10,000#. We tow a lot. We have towed the same trailer with a '98 3/4 ton Suburban and an '06 F250 SD crew cab so that is my point of reference. Gotta' tell 'ya, this is one of the most dangerous tow vehicles I've ever had the displeasure to operate. The trailer sway is real honest to goodness white knuckle stuff.
I'm planning to put Bilsteins on all four corners and replace my front springs with V codes. My plan is to replace the rear, stock leafs with F codes.
I had the truck aligned by a good alignment shop and it was pretty much dead on. The shop said my steering box needs to be replaced but Ford tells me there's nothing wrong with it.
Can anyone offer recommendations/opinions as to what they might do to eliminate or reduce the sway which are specific to my model year?
Thanks a bunch and I really apologize if this stuff is getting old for some of you but we purchased this thing last Fall and we already have many trips lined up for this year, including a big one to San Antonio and Port Aransas, TX late in the Summer.
Stewey, I think you've got it pretty well pegged, none of us should have had to make these mods but Ford blew it for reasons we all speculate about. I don't know about the F codes, I (and most others) put the B codes in the rears. But since I did mine a while back maybe the mod has changed. The V codes make an unbelievable difference in this truck and while you can add air bags and Trac bars to the rear, those things are just compensating for the stock rear springs that are too low in weight capacity and too high in "rate" (pounds of compression per inch). Once you accomplish the spring work and the Bils you will have a totally different truck. Then due some test pulls in different terrain and you may be done! If you still aren't happy my suggestions would be as follows.
1. Upgrade your sway bar to the larger diameter bar that the Superdutys use. You already have the mounts, ends, brackets, etc. You only have to buy the larger bar and bushings. Most guys get the bar for less than$100.00 at the dealer and it's an easy install. Some find a dramatic difference with this upgrade, some find a small improvement, but with your trailer I think it would be an inexpensive upgrade that is worthwhile. I installed the Hellwig to my 01 and that and the V codes were amazing.
2. The only other thing you might want to do is air bags. Some love them some don't care for them. I've had them on other rigs but never on my X. I have a friend that has towed big TT's for years with four different tow rigs I remember. The first thing he does is to install air bags and he always springs for the onboard pump so that he can have air for flats, etc. He will tell long stories about tuning the ride of his rig by adjusting the air and the WD hitch until he has a "perfect" tow.
3. Trac bars (Tuff Country or other lift companies), Landyots (custom, hand built for the X). However at least one poster has said that after the rear spring upgrade he never got around to re-installing his bars because he really didn't have axle hop/wrap anymore. You mileage may vary.
But once again with the springs, the Bils, and the sway bar IMHO your close to perfect. Oh and none of those D rated tires. The E's with the right pressure.
Good Luck,
Jeff
Steering is horrible. It seems that the steering pumps are weak, & the gears were built loose. The '06 steering box is revised as of '05, tighter than loder X models. I will be putting installing the '06 steering gear in my 2000 X.
Another reason your SD handles so much better than the X is that the drag link mounts all the way on top of the passenger side knuckle instead of midship on the tie rod. There is less play than the older X design. That is something you will have to live with unless you lift the truck later & use an aftermarket knuckle. The SD also has less roll & wandering because the coils are further outboard than your X's springs. Start with springs, then see if you still need heavier sway bars, shocks, traction bars, etc.
These are all some of the reasons that i'm currently swapping in the entire suspension system from an '06 F-350. This is far more drastic than most would dare entertain.
Welcome to the Forum! Please tell us whether your Excursion is 4x4 or 4x2. I believe you mean front ball joints and not front control arm bushings, correct? And, at how many miles on the truck did you replace these?
We also tow a 32' TT (9,000 lb typical loaded weight). We use a Hensley hitch (also with WD bars) to keep everything shiny side up.
Thanks!
On the brake rotors, I have been nursing mine along for all of these miles. I plan on replacing rotors/pads in June before the long vacation haul with 32' travel trailer pushing us in stops.
What others are saying here on the forum is that Powerslot rotors with Hawk pads are the way to go. You need to hear from those that have actually made this change.
He has a 95psd that he wants to put a dually rear end under it,we have a dually rear end,but the spring perches need to be moved to match up with the springs this appears not to be difficult job if you know what you are doing
It looks like the hardest part is getting pinion angle right,i have never done one of these but i thought if i get rear end in up against springs ready to weld if i put drive shaft into u-joints that may set the pinion angle close to
where it should be. I am getting all my info. from some of the tv shows on how they build up different vehicles on their shows,thanks
