Here is link to walker exhaust. It shows a part 55366. I am not sure if front pipe with cat is one welded unit and if so don't know how the cat would be pieced back in.
All wrong. Bosals are total pieces of crap. I cannot recommend, and feel that I should warn others to stay away.
If you want to do a weld in, this is the cat you need. Don't screw around with the Magnaflow, they load them with the wrong metals, and many muffler shops are abandoning them because of CEL issues.
This for a little more than that Summit cat will work. Compare the fine details against the Magnaflow and you can tell the difference in quality. Item Details
