catalytic converter choices
Was looking for a replacement for catalytic converters on my '96 351 Bronco...and can only find the complete catalytic system (bolt-on) that is described as fitting the 5.0 Bronco.
forgive my ignorance, but would the same system fit the 351 (hence no separate system listed for the 351) or is there just not a comparable system offered for the 351 as this one:
MagnaFlow 93324 - MagnaFlow Direct-Fit Catalytic Converters - Overview - SummitRacing.com
Should be able to grab any one of the aftermarket deals, then. Try looking at these:
Summit Racing - Catalytic Converters
the 351w is wider so the y pipes are not interchangable. I would either locate a bassani Y pipe for a 95 5.8 and just get another cat added down stream OR locate a very well known exhaust shop and have them make you a new y pipe. I went this route on my 94 since it was actually cheaper then the bassani Y and was just as good in my opinion.
since you have a 5.8 going with a 2.5" diam Y would be advised then go 3" from there out. will really wake up the rig.
grindit60
12-10-2013 10:59 AM
MrErkel
06-02-2013 07:46 PM
