starter engagement problem please help
Old Feb 27, 2011 | 05:46 PM
  #31
berlincam86's Avatar
berlincam86
i have 4 on it now. but it was hitting the exhaust manifold and burned through. i cut the burned stuff and spliced it back together with heavy guage crimps i have a new cable but havent installed it yet.
Old Feb 27, 2011 | 05:49 PM
  #32
arctic y block's Avatar
arctic y block
That could well be a lot of the problem Bud.
Old Feb 27, 2011 | 05:51 PM
  #33
berlincam86
it was doing it before the wire burned though but i will change it out.
Old Feb 27, 2011 | 07:16 PM
  #34
fordjake's Avatar
fordjake
heat increases resistance in wiring which effects the current and voltage my old one i replaced was not long enough to go anywhere else except by the exhaust. make sure you have enough to go under and around away from the exhaust. i hope it helps i know how annoying it is when your truck eats starters for breakfast. i dropped my transmission and all before i replaced my cable.
oahuobx
Nov 9, 2016 05:49 AM
jamesh23
26
Jul 19, 2016 10:47 AM
zdumpor
1978 - 1996 Big Bronco
Jul 10, 2016 03:49 PM
DrZoom
16
Apr 6, 2016 11:42 AM
agaristo77
Apr 6, 2012 01:50 PM
