Gap in tailgate?
Old Feb 24, 2011 | 01:13 AM
dcciie251's Avatar
dcciie251
Gap in tailgate?
Wasn't sure if it was normal or not, so i figured i'd ask.
My '79 has an 8 foot bed, And when I drop the tailgate, The sides of the bed lean outward about 2 inches on either side. Then when I go to close it, I have to push the side back up to get it shut.
Normal?
Or what would you recommend doing to make it a bit stronger?
Old Feb 24, 2011 | 01:31 AM
Sleepy445FE's Avatar
Sleepy445FE
Not normal. I'm not even sure how that would happen, or how I would go about fixing it. How do you push both sides in at the same time to get it to close?
Old Feb 24, 2011 | 02:16 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Sounds like the rear taillamp support structure is broken loose from the bottom of the bed where it connects to the bed floor or it flexes and is weak. Pictures of whats going on may help.
Leaving the tailgate down or off all the time can make the rear bed sides and supports spread apart. The tailgate helps hold the sides together.
Old Feb 24, 2011 | 03:19 AM
mdr617's Avatar
mdr617
I have seen that same problem in another one of these trucks before. It wasent too bad for the one i saw though, the bed sides would just "lean outwards" if the tailgate was down and you put any weight against the inside of the bed sides or lean on it or something.
Old Feb 24, 2011 | 07:21 AM
earthquake68's Avatar
earthquake68
Yeah, your bed sides are fatigued. Two 3" triangle kickers, or gussets welded in at the bottom will help stiffen everything up so that doesn't happen. FIX IT! Before something really bad happens.
Old Feb 24, 2011 | 10:11 AM
NUTTY4X4's Avatar
NUTTY4X4
^^^this^^^it is normal for old trucks that get used as trucks to need some help, my box is so bad that when you open the tailgate it falls off, and another time didnt close right and dragged it a couple miles down the gravel road goin "what is that noise".
Just use a ratchet strap in the stake holes to line it back up straight and weld some small triangles in the corners as well as any fractures in the sheetmetal around that area. .02
Old Feb 24, 2011 | 12:46 PM
81-F-150-Explorer
I wouldn't call it normal. Would call it a comon problem in some situations, in rusty states, trucks without tailgates or with them down all the time etc.. etc...
Old Feb 24, 2011 | 01:01 PM
70 Bronco TX's Avatar
70 Bronco TX
Yeah, I wouldn't call it normal...but like Nutty's idea to get it in place for a fix.
ModelAFord
Mar 6, 2017 02:40 PM
John32369
Aug 17, 2016 03:36 PM
Kurtboyd
Sep 13, 2015 05:02 AM
tabascom16
15
Apr 29, 2015 05:34 AM
1957F100
Feb 19, 2012 09:42 PM
