Textbook coolant flush...
Old Feb 23, 2011 | 10:13 PM
dredmond's Avatar
dredmond
Thanks to all who contribute to the tech folder, it was excellent guidance.
'05 F250, 68,000 mi, first flush.
Several months ago it threw the "wrench" for EOT/ECT differential towing heavy (10K#), no codes in normal driving, no coolant loss. The coolant was darker than new but no apparent oily content. I am hoping this will at least delay replacement of the oil cooler and EGR cooler.
  • 2 qts. VC-9
  • 30 gal distilled water - 4.5 gal/flush
  • dropped the driver side block plug and bottom rad. hose
  • removed the t'stat, (dealer gave me a new "o" ring too large)
  • 3.5 gal. Ford Premium Gold
I was fortunate not needing to remove the air filter or plenum, or force any other lines to get to the t'stat housing bolts. There must have been a modification... Pulled it right out, leaving the hose attached.
I did install a coolant filter while I was at it also.
Again, thanks for all the technical support!
How do I post pics? I have samples of all the flushes to post if I can figure out how to post them... Probably did not need the last flush, there was no significant difference in the last two.
Old Feb 24, 2011 | 08:14 AM
Cowboy65's Avatar
Cowboy65
Originally Posted by dredmond
How do I post pics?
Following info is from the FAQ section of the forum. There is lots of good info there on general forum usage.
Ford Truck Enthusiasts Forums - FAQ: Reading and Posting Messages
How do I add an image to a post?
If you have uploaded an image as an attachment, you can click the arrow next to the 'Attachment Icon' and select it from the list. This will be inserted into your post and can be located where you want it displayed.
To include an image that is not uploaded as an attachment and is located on another website, you can do so by copying the full URL to the image, (not the page on which the image is located), and either pressing the 'Insert Image' icon or by typing [img] before the URL and [/img] after it, ensuring that you do not have any spaces before or after the URL of the image. You can insert pictures from your albums (?) in this way too.
gwg42
Feb 25, 2013 08:25 AM
Sullid01
Jan 13, 2013 10:08 PM
YoungFordAddict66
33
Mar 14, 2012 02:37 PM
refer guy
Jun 6, 2010 03:45 PM
69cj
Oct 27, 2009 07:11 PM
