T-stat change help
Old Mar 11, 2012 | 03:30 PM
YoungFordAddict66's Avatar
YoungFordAddict66
T-stat change help
Ok I have my oil cooler rebuild kit, 4 gals of oil, 4 gals of fleet charge coolant, 24 gals of distilled water. So the plan is to drain the oil and coolant, take the oil cooler of and replace the gaskets and o-rings, then flush the coolant system. But i figured since im draining the coolant i should change the t-stat out since i think its sticking open. After some reading I should get a Ford t-stat correct? I've found a 203 t-stat at napa for my 95 but have read about o-ring problems IIRC? Any think im missing or should change out too while im in there?
Old Mar 11, 2012 | 03:43 PM
fordpride's Avatar
fordpride
I would get it from Ford or IH
Old Mar 11, 2012 | 04:03 PM
YoungFordAddict66
Thats what i figured thanks Mike. Is the o-ring on the one from ford ok? Not to small or any of the other problems like the one from the parts store?
Old Mar 11, 2012 | 04:49 PM
fordpride's Avatar
fordpride
I've only changed mine one time and that's when I put the 203* in
Old Mar 11, 2012 | 10:51 PM
oldbird1965's Avatar
oldbird1965
smokerblack will tell you all about it Blake, LOL!! Diesel site has a good T stat neck, better then our stock ones.
Old Mar 12, 2012 | 01:16 AM
pjwoolw's Avatar
pjwoolw
Blake you might want to get some allen head bolts for the housing. Much easier to reinstall. They are metric.
Old Mar 12, 2012 | 02:58 AM
YoungFordAddict66
Haha nice Glenn. And is a new neck nessecary or is more just for insurance?
Pete thanks for that part number. And ok I'll look into that.
Old Mar 12, 2012 | 10:01 AM
oldbird1965
insurance.
Old Mar 12, 2012 | 01:21 PM
pjwoolw's Avatar
pjwoolw
Thank Jose for posting this up some time back.
The bolts are: flange bolts M6 1.0 pitch and 20 mm long.
Old Mar 12, 2012 | 03:18 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I would get a reinforcing ring for the t-stat housing. it will come with new bolts and a new o-ring.
T-Stat Housing Ring
Old Mar 12, 2012 | 04:34 PM
YoungFordAddict66
So Trav thats just a reinforcment for the housing so you dont tweak anything and the o-ring gets even pressure?
Old Mar 12, 2012 | 04:41 PM
strokin'_tatsch
Correct. It also replaces the stock square cut o-ring with a better o-ring.
Old Mar 12, 2012 | 05:12 PM
YoungFordAddict66
Hmm i' ll have to see how bad the housing kneck is when i start all these projects and see if i need that and a new kneck. Im going to ford today to get a new t-stat and y-pipe gasket so i might see about a kneck. Im using your oil cooler write up to knock this thing out here in a couple days, that write up makes it sound a lot easier then i though it would be.
Old Mar 12, 2012 | 05:17 PM
strokin'_tatsch
Once you get into it, you'll realize it's a fairly easy project. Getting the end caps off and back on the oil cooler is the worst part.
Old Mar 12, 2012 | 05:31 PM
YoungFordAddict66
Haha thats when a BFH comes in handy. Lol
