Problems!?
Old Feb 23, 2011 | 07:48 PM
blueovalbigblock's Avatar
blueovalbigblock
Problems!?
So my idle has always moved a little up and down and i never really paid any attention to it but now it will jump and then act like my truck is going to die and jump bcak to normal. i have changed my fuel filter, all my fuel lines, changed idm and pcm, cleaned connections on my chip, cleand fuel pressure reg screen, i have a hpx and that helped a little but not much. any ideas what my problem could be? bad fuel pump? bad injector? they are not very old so they beter not be goin out lol i heard it could be a ground problem to do with my pcm/ts chip, any idea what ground to check? any ideas would be great thanks!
Old Feb 23, 2011 | 07:55 PM
Action4478's Avatar
Action4478
Look at the ICP sensor , it is most likely leaking oil (seeping)
Next to the lifting ring on the DS head..
Also , if you have an auto trans , it my be the TRS . Try starting it in neutral ....
Old Feb 23, 2011 | 08:01 PM
blueovalbigblock
it is a manual but thanks. where is the icp sensor? do you mean the one on the hpop or am i thinking the wrong thing?
Old Feb 23, 2011 | 08:04 PM
Action4478's Avatar
Action4478
ICP pic .....Name:  ICP Pic.jpg
This is from a newer truck, but the sensor is in the same place
Old Feb 23, 2011 | 08:06 PM
blueovalbigblock
thanks sorry i re read that and realized i was stupid lol
JDSIMPSON55
Mar 17, 2017 04:11 PM
427 fordman
17
May 14, 2011 07:11 AM
bryanlindborg600
Feb 25, 2011 01:05 AM
Chief150
Oct 19, 2010 08:00 AM
cleatus12r
32
Sep 5, 2008 09:07 AM
